Results 1 to 4 of 4
Thread: Tuning for new larger tires. Need Help
    Sep 2005
    Default Tuning for new larger tires. Need Help
    I went from a 31inch tire to a 33inch tire and EFIlive readjusted my transmission settings. However Ive also noticed that my LTFT's are at +10 more often. Can anyone explain. SOS!
    2002 GMC Sierra ECSB
    Turbonetics T7675 6lbs boost, 42lb injectors, Single 4 inch exhaust with Hi-Flow Cats, 6.0 swap, Comp Cam LS9 Cam, EFIlive Tune, E-fans, Snow Performance Meth Kit, soon to add KB Boost a Pump,
    Jan 2005
    Installing larger tires has the same effect as switching to a higher (lower numerical) drive axle ratio (that's the politically correct replacement term for rear axle ratio). The higher the ratio, the less torque multiplication which means the engine has to work harder. It may just be that the engine is now running under enough of a load increase that it's getting to parts of the VE and spark tables that it didn't previously. If you logged data before and after the tire change, check MAP under similar operating conditions. You'll probably find that MAP readings are now noticeably higher than they were with the original tires.
    Sep 2005
    Thanks! I'll try that. Has anyone else run into the same problem? My tires were originally 275-75-r16 new ones are 285-75-r16 a gain of 2 inches in diameter. Please advise
    Sep 2005
    Quote Originally Posted by jamesbond2509
    :? :? :? You shouldn't be gaining 2" in diameter by only adding 10mm to the width???
  1. 668Hp/1189Ftlbs at the tires in LBZ on #2 only and EFILive!
    By Danville Performance in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 28th, 2011, 04:19 PM
  2. Correct Spedo For Larger Tires
    By dobby in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 30th, 2008, 11:38 AM
  3. Basics for tuning with a larger cam
    By LuhrsTSF342 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 10th, 2006, 04:31 AM
  4. Idle tuning for larger TB with ETC.
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: April 2nd, 2006, 06:07 PM
  5. Is it a bad thing when front tires come off the ground?
    By Danville Performance in forum General (Petrol, Gas, Ethanol)
    Last Post: February 20th, 2006, 03:34 PM
