Results 1 to 1 of 1
Thread: custom pid for GM.ENGOILP ...inside... sticky info
    Oct 2007
    Default custom pid for GM.ENGOILP ...inside... sticky info
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter Value Description
    VERSION 7.1.1 File version
    DECSEP . Decimal separator used in this file
    # Units
    *UNITS
    #Code System Abbr Description
    # Add slot definitions here
    *CLC-00-021
    AFR 10.0 20.0 0.2 "{EXT.AD1} * 2 + 10"
    *CLC-00-022
    AFR 10.0 20.0 0.2 "{EXT.AD2} * 2 + 10"
    *CLC-00-031
    factor 0.5 2.0 0.3 "{CALC.AFR_WB1} / {GM.AFR}"
    *CLC-00-032
    factor 0.5 2.0 0.3 "{CALC.AFR_WB2} / {GM.AFR}"
    *CLC-00-121
    AFR 6.0 14.0 0.2 "{EXT.AD1} * 1.6 + 6"
    *CLC-00-122
    AFR 6.0 14.0 0.2 "{EXT.AD2} * 1.6 + 6"
    *CLC-00-131
    factor 0.5 2.0 0.3 "{CALC.AFR_E85_WB1} / {GM.AFR}"
    *CLC-00-132
    factor 0.5 2.0 0.3 "{CALC.AFR_E85_WB2} / {GM.AFR}"
    *CLC-00-210
    psi 0.0 100.0 0.1 "{GM.EOPS} * 32 - 16"
    kPa 0.0 700.0 0.1 "{GM.EOPS} * 220.6 - 110.3"
    CALC.AFR_WB1 F021 CLC-00-021 AFR "Wideband" "Wideband AFR 1"
    CALC.AFR_WB2 F022 CLC-00-022 AFR "Wideband" "Wideband AFR 2"
    CALC.BEN_WB1 F031 CLC-00-031 factor "Wideband" "Wideband BEN 1"
    CALC.BEN_WB2 F032 CLC-00-032 factor "Wideband" "Wideband BEN 2"
    CALC.AFR_E85_WB1 F121 CLC-00-121 AFR "Wideband E85" "Wideband E85 AFR 1"
    CALC.AFR_E85_WB2 F122 CLC-00-122 AFR "Wideband E85" "Wideband E85 AFR 2"
    CALC.BEN_E85_WB1 F131 CLC-00-131 factor "Wideband E85" "Wideband E85 BEN 1"
    CALC.BEN_E85_WB2 F132 CLC-00-132 factor "Wideband E85" "Wideband E85 BEN 2"
    CALC.EOP F210 CLC-00-210 "kPa,psi" "Conditions-Oil" "Engine Oil Pressure (calculated)"
    SO FOR THIS TO WORK YOU WILL NEED TO ENABLE......
    1.....CALC.EOP (LOCATED IN CONDITIONS-OIL) MAKE SURE THIS IS CHANGED TO IMPERIAL...
    2.....GM.EOPS (LOCATED IN CONDITIONS)
    Also listed is my custom PID for my LC-1.... That might help people as well
    BIG THANKS TO JOECAR, THIS IS HIS WORK, ALL OF THE CREDIT GOES TO HIM...
    01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
  1. Idle Tuning - Helpful Info Inside
    By SSpdDmon in forum Tutorials
    Last Post: September 5th, 2017, 08:54 AM
  2. HOW TO....enable GM.ENGOILP
    Last Post: December 15th, 2009, 01:47 PM
  3. 3 Bar sticky
    By autostaff in forum Gen IV V8 Specific
    Last Post: July 16th, 2009, 09:11 AM
  4. Idle Tuning - Helpful Info Inside
    By SSpdDmon in forum Gen III V8 Specific
    Last Post: February 27th, 2007, 02:15 AM
  5. Should we make a sticky and post in our "custom scripts
    By wait4me in forum General (Petrol, Gas, Ethanol)
    Last Post: February 2nd, 2006, 04:02 PM
