Hi
Can somebody help?
I have done some auto ve tuning during the last days. When I past in the ve correction it seams like I change the same sells over and over again.
I then started to look at my data filters. Every time I restart my tuning tool the value in the data filter are reset to zero. In addition to this it seams like the filter do not work.
To be certain I have set up a filter that should “exclude data frames” “engine rpm” “less then” “2000,00” rpm. (Should be weary easy to see on the map). When I apply this filter nothing happened neither with my Map, or my dashboard view. I have EfiLive installed on three different computers, all acting the same. I have reinstalled the latest version on my laptop after cleaning up the register. And checked that my Flashscan have the latest firmware.
After the reinstall I made a new map, and new pid selection. (No copying of old files)
I then connected the computer to the flashscan and the flash scan to the car. After logging some idle and part throttle data I tried to set up and apply a filter. It does not exclude anything.
If I make the filter “exclude data frames” “engine rpm” “greater then” “2000,00” rpm. All my data disappear, even the idle cells.
What can be wrong? Please help?
Tor
