Results 1 to 4 of 4
Thread: im having a problem with the crank relearn
    Senior Member whackem04's Avatar
    Apr 2009
    Default im having a problem with the crank relearn
    I have let the truck warm up, have the truck in park, foot on the brake and i press the button to relearn and nothing happens or it says no reply try again.
    Anybody else used it lately? am I missing something?
    01 GMC Sierra 1500 SLE 5.3 cam swap
    Tuned by ME (COS 5 - running strong and smooth)
    After you click the button, you have about 10 seconds in which you have to increase throttle to bring the RPMs upto above 4000 or 4500...
    when you hit the right RPM, the PCM will cut fuel momentarily causing stumble for a brief moment, you will notice it...
    immediately when it stumbles, release throttle and let engine spin down to idle on its own...
    after reaching idle wait a few seconds and then turn engine off (key all the way to OFF), and wait at least 15 seconds with key off.
    Also note: for this to work ECT must be in the specified range, in addition to brake switch indicating brake pedal applied.
    Apr 2009
    thanks! ill try it again. does it let you know that it has completed?
    Quote Originally Posted by whackem04 View Post
    The stumble indicates that the relearn has initiated...
    after the stumble, when you let the engine spin down on its own, the PCM collects data... one of the things it collects is the natural rate of deceleration of the crank... this is later used by the misfire algorithm.
    it doesn't let you know that it's finished... but the stumble lets you know that it has initiated.
  1. crank relearn??
    By 2004gmc in forum Lounge
    Last Post: July 30th, 2021, 12:24 PM
  2. E38 5.3 LMG Crank relearn
    By harascho in forum Gen IV V8 Specific
    Last Post: December 4th, 2008, 08:04 AM
  3. crank relearn
    Last Post: August 28th, 2008, 06:07 AM
  4. Crank Relearn
    By mk6racer in forum Gen III V8 Specific
    Last Post: May 15th, 2008, 11:05 AM
  5. Problem Performing Crank Relearn!!!!!! I need help quick
    By 01Blackerado in forum Gen III V8 Specific
    Last Post: October 24th, 2007, 08:15 AM
