Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: can anyone convert ant hpt file into efi?help,help
    Dec 2009
    Default can anyone convert ant hpt file into efi?help,help
    Im trying to copy my tune from my car into efi live. but i cant cause the tables are different. Whos has the ability to convert an hpt to efi? how much would it cost?
    file below. this is for an 02 os a4
    Hi z28LS1818,
    If the following are all true:
    - that tune is already in your PCM,
    - that tune is not an HPT custom OS,
    - you have FlashScan V1 or V2,
    then you can directly read that tune from your PCM using EFILive.
    Dec 2009
    forgot to clarify. this tune is not in my pcm. i am using the rr pcm and my interface is not licensed to ready any pcm via the tuner, its only for scanning purposes. i only have a license for the rr pcm via the usb port. this tune is not. anyone hlep lol
    I'm told it is encrypted and can't be cracked...
    Do you know anyone with HPT...?
    They can flash it into your PCM (you would owe them some credits), and then you can read it via the RR interface.
    Dec 2009
    it shouldnt be encrypted. what is exactly encrypted?
    my friend has hptuner with unlimited vins, he tried to write my pcm but it wouldnt let him. we just assumed it was because of the rr pcm. any ideas.
    Dec 2009
    Quote Originally Posted by mr.prick View Post
    You can read any supported PCM,
    as long as it is not loaded with pptuners COS.
    when i try to read via the obd2 it says interface not registered,invalid!
    Nov 2006
    You can't read an RR thru OBDII or with pptuners.
    If you can put the stock PCM back into the car then do that then read it,
    or use a bench harness.
    LC-1 WBO2
    Dec 2009
    i cant read any pcms vis the tuner it wont let me. it says invalid interface. my cable is scan only. which IMO its bull that i cant read via the tuner.
    Nov 2006
    Scan only can read, did you try reading a stock PCM?
    LC-1 WBO2
    Dec 2009
    yes. tried reading one off a silverado cause we were going to flash the hp tune on there then read it with my efi cable, but it says interface invalid not licensed or something like that.
  1. Convert ETC to cable TB
    By xtreme in forum Gen III V8 Specific
    Last Post: March 23rd, 2009, 10:52 PM
  2. Anyone willing to convert my PLX to serial???
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: November 16th, 2008, 04:51 PM
  3. Convert 98 to 02
    By ChipsByAl in forum Gen III V8 Specific
    Last Post: June 26th, 2007, 05:23 PM
  4. Convert LS1Edit File to EFILive ... Help!
    By superls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2006, 03:00 PM
  5. LS1 Edit convert... first post with Q's
    By Chicago Z06 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 15th, 2005, 08:11 AM
