Results 1 to 3 of 3
Thread: OmniTuner DUAL-FLASH
    Nov 2007
    Default OmniTuner DUAL-FLASH
    The OmniTuner DUAL-FLASH is a member of the OmniTuner line of products by Digital Inflection Corporation. This device allows you to install two separate flash chips in one Powertrain Control Module. Most GM Generation III applications are supported but when ordering specify which PCM you have so that the DUAL-FLASH has the proper flash chips installed. GM used both 512k and 1 megabyte flash chips in the GEN III PCMs.
    The DUAL-FLASH replaces the flash chip that was installed by the factory with two separate OEM flash chips that individually appear to the PCM as a single flash chip when selected. Through the use of a switch of your choice you have the ability to select which one of these flash chips is used by the PCM. You have the ability to switch between flash chips only when the ignition is in the “off” position to prevent accidently switching between flash chips when the car is running.
    Possible applications for the DUAL-FLASH include tuning a vehicle for multiple fuels, assuming this tuning is compliant with emission regulations. You can use ethanol based fuels when available and switch back to conventional fuels when desired. Additionally you might choose to tune one flash chip for fuel economy but leave the other flash chip stock. Any tune that you can flash to a stock PCM can be flashed to either one of the flash chips of a DUAL-FLASH enabled PCM.
    http://www.moates.net/product_info.p...roducts_id=218
    Oct 2004
    Saw another post on our forum recently about that product. Looks pretty cool for sure! Would be awesome if you could switch flash banks without having the shutdown the car
    Andrew
    EFILive Crew
    Aug 2006
    Remember the ZR1 (LT5 engine) that had the key on the dash to switch between normal and full power? That would be a cool implementation of the dual flash.
    Nice work.
    24x LS1 PCM on Early Small-Block Chevy and LT1/LT4
    http://www.eficonnection.com
  1. Licening The OmniTuner DUAL-FLASH chips?
    By kbracing96 in forum Purchase and Shipping
    Last Post: March 9th, 2010, 01:03 AM
  2. FAST dual WB to EFI V1
    By rickou812 in forum External A/D inputs
    Last Post: November 19th, 2009, 09:06 AM
  3. FAST DUAL O2's
    By alz28 in forum Tutorials
    Last Post: August 28th, 2008, 06:54 PM
  4. Dual PCM
    By Jo2 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 14th, 2007, 12:13 PM
  5. dual fast 90 set up
    Last Post: June 7th, 2006, 01:52 PM
