I installed an 18" Electric fan on a 2000 Silverado 5.3ltr 4WD. I wired up a relay and used pin #42 on PCM blue connector. I know pin #42 supplies the ground to turn on relay....In the tune I made changes so fan will turn on! But as soon as I start the truck the fan click's on and stay's on. I changed the turn on/off temps, switched to series parallel fans and then to back to auxiliary fan...
In the scan tool under DVT controls I activate the cooling fan setting and the fan turns off. Weird!!! I can turn on and off the fan while under DVT controls... But as soon as I de-activate the fans turn on again...!!! Anyone know why the fan is staying on? Should I try pin 33 on red connector? This is a first for me.....Will post up tune file.....
Thanks in advance!
