I don't see the Base Efficiency Numerator PID on the list for the LS1-B ??
Since its a CALC PID, what you need to do is click the little V7 button in the PID selection window and type BEN1 (for serial BEN factor) or whatever CALC.BENxxxxx you want. Omit the prefix CALC. though. Read the little blurb in there too, makes more sense.
no idea what you are talking about
See pic...
Calc pids are predefined for various things like the wideband analog BEN amd AFR pids...
You can also define you own calc pids in C:\Documents and Settings\Joe\My Documents\EFILive\V7.5\User Configuration\calc_pids.txt.
BBL logging normally can't log calc pids, until now... see pic.
Joe I DO NOT have that button on my software.
I have a "configure switchable tunes" button in that same location. ??
What version of the software do you have?
LC-1 WBO2
Version 8.1.2 Build 58
Current version is in my sig.
You will need to update the software to get the calc_pids to load up with BBL.
LC-1 WBO2
this is what I found on the web site
June 09, 2009: EFILive V7.5.5 (Build 88)
June 09, 2009: EFILive V8.1.2 (Build 58)
June 09, 2009: FlashScan And Autocal Firmware (V2.06.12)
so where do you get the newer ones ??
Try this link:
http://forum.efilive.com/showthread....679#post105679
FLASHSCAN V2 & AUTOCAL
