Results 1 to 4 of 4
Thread: BBL & Serial LC-1
    Nov 2007
    Default BBL & Serial LC-1
    Well I'm new to auto VE but I did everything that was mentioned to do.
    everything seems to work fine only the BEN map in the scan tool is all 00000.
    Nov 2007
    Never mind I got it figured out.
    Nov 2006
    Did you figure out that you can add call_pids to a saved log?
    LC-1 WBO2
    What was the solution...?
  1. plx sm-afr serial
    By blazinblue in forum General
    Last Post: June 23rd, 2009, 07:29 AM
  2. LC1 serial to V2
    By nonnieselman in forum FlashScan V2
    Last Post: November 12th, 2008, 01:58 PM
  3. LM1 through the 9 pin serial...
    By rubbersidedown in forum FlashScan V2
    Last Post: August 2nd, 2008, 02:00 AM
  4. WB serial to LT serial?
    Last Post: May 12th, 2008, 09:17 AM
  5. OBD to serial to USB
    By kjhansen in forum EFILive V4
    Last Post: April 6th, 2008, 02:20 AM
