Results 1 to 10 of 14
Thread: diesel exhaust fluid
    Apr 2008
    Thumbs down diesel exhaust fluid
    Any one heard of this?
    as of 2010 dodge,chev,ford must use to meet epa reg.
    lol next on the delete list like the dpf
    stock sucks
    Dec 2008
    Urea injection. Basically ammoina from what I understand. Cuts down on NOx emmissions
    Jan 2008
    Quote Originally Posted by tokymon View Post
    I was under the impression that the 6.7 cummins had already met the 2010 epa emissions standards without the use of the urea injection...
    Mar 2009
    Quote Originally Posted by analreject View Post
    I thought it was piss, but ammonia works too I guess. Aren't they already using this in Europe?
    Quote Originally Posted by bballer182 View Post
    That's the word, but that doesn't mean Dodge won't have to resort to it in another few years. It seems like a bandaid fix until the manufacturers can find a better way to catch up with the emissions requirements.
    Jan 2008
    I really don't see what the problem is. I think that the urea injection is a really good idea. It's not like its a performance inhibitor like the DPF or the CAT. It's just and injection into the exhaust and if it reduces bad emissions then GREAT!
    Apr 2008
    ya it all sounds good but from what i have read it will go into limp mode if you run out. and it will be another fluid that can frezze not so good when it's been -30*c here for a week
    stock sucks
    Jan 2008
    What is the freezing point on the urea fluid anyways?
    Sep 2005
    I didn't find the freezing point, but I did find that it is uses as de-icer for air planes, so I don't think you have to worry about it freezing.
    Jun 2005
    No problems in Europe
    Roy 98SSSSSS
    Apr 2008
    are supplyer at work says -4*c
    stock sucks
  1. Possible PCM fault from Welding Exhaust
    By The Alchemist in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2010, 08:52 PM
  2. Exhaust flames on over run
    By Tre-Cool in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 3rd, 2010, 06:11 PM
  3. LBZ exhaust temps
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 23rd, 2008, 10:24 AM
  4. DPF Delete and exhaust question
    By clickjocky in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 21st, 2007, 11:40 AM
  5. DFCO and Exhaust popping
    Last Post: November 12th, 2006, 05:29 PM
