Results 1 to 10 of 12
Thread: COS 3 timing question
    Member CC&M's Avatar
    Dec 2008
    Default COS 3 timing question
    I'm using 02020003 and have what is probably going to amount to a stupid question. No matter where I set the timing tables it will not go over 32 degrees of timing. I have raised the amount of timing in B5913, B5919 as well as zeroing out the tables I don't use. I have logged the EST_PID's and have not found any that are removing timing. I uploaded my .tun if anybody wants a look.
    Post some logs.
    Dec 2008
    Here are a couple that I have done yesterday and day before.
    Dec 2008
    Logs are posted, anybody seen anything that resembles this? Would really like to get this solved.
    Can you log GM.DYNCYLAIR and GM.EQIVRATIO also...?
    I can't see what's wrong (other than LTFT's are large).
    Fix the out of range values in A0012, A0013.
    Try this experiment: set A0000 to Enable, set A0001 to 100%...
    If you now get the correct timing, set A0000 to Disable and see what timing does.
    Dec 2008
    Thanks Joecar,
    I'll try logging it to see what I get. I did have A0000 enabled at one point with A0001 at 50%. When it was like that it blended the tables perfectly. My LTFT is like that because it has a big percentage of E85 in it. I had a couple jugs left over after race season that I dumped into the pickup to use it up. I'll set A0013 and A0014 to lower values, they don't show up as out of range on my computer.
    Oops, I meant GM.EQIVRATIO... I corrected its spelling in my post above.
    Dec 2008
    Joecar,
    Here are a couple quick logs that I did earlier after I made the changes to A0000 and A0001. The timing still tops out at 32.5 even though the forced octane scaler is at 100%. Now I don't feel so bad that I haven't been able to find what is wrong. 0024.efi is a cruise type situation. 0025 is a full throttle run, or at least the best I could get on a wet road due to wheelspin.
    Oct 2006
    Wouldnt hurt to log GM.ASPARK with those pids.
    The Tremor at AIR
    Dec 2008
    Here are some more logs with adaptive spark logged. I have also logged the EST.PIDS in the past and come up with nothing conclusive either.
  1. a question about AFR and timing
    By A.O.A in forum General (Petrol, Gas, Ethanol)
    Last Post: June 25th, 2009, 07:25 AM
  2. Timing question
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: May 14th, 2009, 01:09 PM
  3. Timing Question
    By esco35m in forum Gen III V8 Specific
    Last Post: September 4th, 2008, 01:04 PM
  4. Question on 454 Spark Timing
    By N0DIH in forum Vortec V6/V8 Specific
    Last Post: July 14th, 2007, 04:24 AM
  5. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 03:22 PM
