Results 1 to 10 of 14
Thread: Logging with v2
    Aug 2008
    Default Logging with v2
    Okay is it possible to data log with only the v2, and not the laptop with v7.5? So far I could only figure it out using the v8.1 build (58 I believe) which is fine but with the 8.1 I cant find any pre-made pid lists ( duramax lbz imperial is what I want). I have to make my own list and cant seem to find all the pids... i.e. Main1Q_dma for example.
    I made my own pid list with the 8.1 in the mean time but they all display metric.
    Nov 2006
    Build 58 is pretty old,
    if it doesn't use the scan&tune software to configure the options.txt
    IIRC
    You need to look up the PID's in the pid_descriptions.txt and copy it to the options.txt
    The options.txt must be formatted with the same name of the PID that is in the pid_discriptions.txt
    LC-1 WBO2
    Aug 2008
    Where can I download the newest BBL version?
    Oct 2004
    Latest pre-release version is here: http://forum.efilive.com/showthread.php?t=12587
    Andrew
    EFILive Crew
    Madmax,
    What are the bootblock/firmware versions of your FlashScan V2...?
    Apr 2008
    The build 58 has a bug that did not allow setting the PIDs to a different scale like Metric to Imperial. Now once you get all the PIDs selected and change to the scale you wish to see and this is with the newer version as mentioned above you upload to the Flashscan. Now once you plug it into the truck you have to select the controller which is the list name you used in the F1 section. Now goto view the logging and it will show in metric. Press the enter key and then the change to the other scale you selected in the ScanAndTune software.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
    Aug 2008
    Madmax,
    I'm not sure how to figure that out?
    Oct 2004
    Connect the device to your PC and then open up EFILive Explorer. Down in the system tray you will see an ion that looks like your V2. If you click on that icon it will open up the EFILive Control Panel. Then change to the F6: Firmware tab and it will show all the details.
    Andrew
    EFILive Crew
    Aug 2008
    I downloaded the newest build, and looks like I'm set... Have all the PIDS I need already in a premade list.
    Thanks Guys
    Aug 2008
    Andrew, I will try that.. But heres the thing. We use my brothers computer for EFI LIVE, because this one is pretty slow. If I plug the V2 into this computer will I have to do anything special like idk if my v2 is locked to my brothers computer or anything. Basically can I plug it into this computer without any troubles?
    Do you have a link to where I can download the explorer? I don't have that loaded to this computer.
  1. Logging LMM's
    By schuter in forum Diesel
    Last Post: March 20th, 2008, 01:26 AM
  2. Logging L76
    By JezzaB in forum Gen IV V8 Specific
    Last Post: June 11th, 2007, 10:10 PM
  3. Logging RPM
    By oztracktuning in forum Black Box Logging
    Last Post: January 20th, 2006, 05:55 PM
  4. I have a few Q's about logging.
    By SmaknSS in forum General
    Last Post: December 1st, 2005, 05:33 AM
