Results 1 to 3 of 3
Thread: Same PCM, different vehicle and years?
    Junior Member m396 #00-011's Avatar
    Oct 2003
    Default Same PCM, different vehicle and years?
    I had a problem with a PCM. I have a backup PCM from a different year. With Commercial version, can I change that pcm to a different vehicle?
    The only problem I see is, the needed pcm is an 03 truck, the backup is a 00 car. In the past, I was told pcms followed the 97-98, 99-00, 01 and up type.
    Can someone confirm?
    Thanks,
    Jason
    Jason Woolverton
    2000 Mallett FRC
    2003 Silverado SS
    Mallett 396's Garage
    Oct 2003
    I believe the '03 is different from the 99-02 series. I think the 99-02 have blue and red PCM harness connectors, where the 03 has blue/green. Also, I think the 99-02 had 512k flash size and the 03 has 1024k.
    May I ask what happened with your PCM?
    2003 Silverado SS
    N/A: 14.257 @ 94.63 mph
    N2O: 13.200 @ 102.3 mph
    Oct 2003
    I'll PM you about the PCM, :cry:
    I know the memory differences in the years, but didn't know if I was running a custom OS, If I could get around that. I quess it depends on how much memory the 03 PCM program really uses. I quess I could look at the program sizes....
    Bad timing, all the knowledge is at SEMA :cry:
    Jason Woolverton
    2000 Mallett FRC
    2003 Silverado SS
  1. 4.8 differences over the years...
    By DURAtotheMAX in forum Gen III V8 Specific
    Last Post: April 23rd, 2011, 09:59 PM
  2. What Years for Which ECM
    By Ninety8C5 in forum Lounge
    Last Post: October 9th, 2009, 03:51 PM
  3. ITs been YEARS
    By ssdungeon in forum Gen III V8 Specific
    Last Post: September 9th, 2009, 08:37 AM
  4. The next 5 years
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: February 6th, 2009, 10:25 AM
  5. Diffrences through the years
    By cmitchell17 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 10th, 2007, 10:26 AM
