Results 1 to 10 of 11
Thread: Add the ECM AFM1500 to the serial WB list!
    Default Add the ECM AFM1500 to the serial WB list!
    just wanted to thank paul and joe for helping me getting our AFM1500 Wide Band to talk to the V2! It was a bit of a pain as the RS232 language can be quite confusing. Needless to say its working like a champ.
    For those that are not familar with the ECM product line these are very quality units. ECM has been the supplier to GM and Chrysler for years with high end wb units. Most of which can be well over $50K!
    http://www.ecm-co.com/index.asp
    This particular units is significantly cheaper and has been flawless and very stable.
    This is not the novice level device but any shop that wants no BS lambda monitoring should consider there non OE level units. I think Joe was going to do a sticky on the setup so please add this to the list of V2 compatible WB's.
    Thanks again!
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Nov 2006
    You guys finally got it going!
    I remember when you first asked about supporting it.
    It seems like a long time ago.
    LC-1 WBO2
    Howard,
    I'm not familair with the AFM cable... where does it plug into on the AFM, can you post a pic of it...?
    The connection is like this:
    FlashScan V2 DB9 serial cable --> null-modem adapter --> AFM serial DB9 cable (AFM1500A-16)
    Does that look right Howard...?
    We were trying to logic out RS232's reversal of TX/Rx pins 2/3...
    Howard he ohmed all the signal wires to see which went where...and he contacted Fabio at ECM to ask for the soft protocol... it turns out the AFM requires commands to be sent to it to request the Lambda/AFR.
    Howard got it talking and saved the trace file...
    from the trace file Paul was able to verify that the AFM was responding correctly to commands from V2 and that V2 was receiving the responses correctly.
    The new V2 firmware has support for the AFM... in V2 setup options the serial com has to be set to WO2 and the wideband type has to be set to ECM.
    Thanks Howard......that's a lot of work while trying to run your business.
    Howard,
    I'll add step by step later... I'll attach the AFM pdf user manual.
    Joe,
    There are two 9 pin female plugs on the AFM box. The one that is marked SMB/PC is the one that receives and transmits the serial data.
    The big problem was that the AFM plug does not use the same universal RS232 pins as the rest of the industry, hence the need for there AFM1500A-16 cable which flips the pins. The null modem flips the Rx/Tx pins.
    Now the next trick will be getting that same serial data into the dyno!
    Howard
    1-954-703-5560
    Feb 2009
    Big thumbs up. Just installed and seamless with the instructions above.
    For those yet to install...the only small glich I ran into was insuring the ID1: and ID2: fields in the Autocal setup, matched the AFM1500. Default values of 0,1 respectively and the AFM1500 came as 1. V2 indicated "W02 Not Found". Changed the Autocal setup to 1,0 and it's displaying away.
    Pretty trivial info but might be usefull for the next guy installiing.
    First start, already see source of my cold stumble with + throttle change. NICE.
    Quote Originally Posted by diablo View Post
    Thanks for the feedback
    So the wideband id's are 1 and 0 instead of 0 and 1, did I understand correctly...?
    Feb 2009
    For my scenario, yes. However, I think the point is that ID1: in the EFILIVE setup for this WB needs to match the AFM1500 ID.
    Were you using 2 widebands concurrently...?
    Feb 2009
    Negative. Only one on bank 1.
    Mar 2009
    What is the gong price for on of these ECM AFM1500 and where do you buy them in Australia?
  1. TCM OS List
    By TBMSport in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: June 4th, 2010, 01:33 AM
  2. list of 411 pcms anyone?
    Last Post: April 19th, 2010, 09:49 AM
  3. how to get my pid list to v2?
    By 2004gmc in forum Lounge
    Last Post: May 30th, 2009, 09:52 AM
