Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
Thread: 99 Saturn crack log
    Dec 2009
    So I was thinking about the memory map this morning and it dawned on me that the biggest section of memory that I did not know what was going just so happened to be about $1100 to $1fff. There is something else. That fits those numbers very well, the mode $22 pid list. I have a feeling the pid's fit into those locations directly.
    Dec 2009
    So is it just me or does this look like the kind of table that would make one of those pretty 3d graphs.
    AC9D db $FF, $FF, $FF, $FF, $F3, $E6, $DC, $D4, $CD, $C7
    ACA7 db $C2, $BD, $B9, $B5, $B1, $AE, $AB, $A8, $A6, $A3
    ACB1 db $A1, $9F, $9D, $9B, $99, $97, $95, $94, $92, $91
    ACBB db $8F, $8E, $8C, $8B, $8A, $88, $87, $86, $85, $84
    ACC5 db $83, $82, $81, $80, $7F, $7E, $7D, $7C, $7B, $7A
    ACCF db $79, $78, $77, $77, $76, $75, $74, $73, $73, $72
    ACD9 db $71, $70, $70, $6F, $6E, $6E, $6D, $6C, $6B, $6B
    ACE3 db $6A, $6A, $69, $68, $68, $67, $66, $66, $65, $65
    ACED db $64, $63, $63, $62, $62, $61, $61, $60, $60, $5F
    ACF7 db $5E, $5E, $5D, $5D, $5C, $5C, $5B, $5B, $5A, $5A
    AD01 db $59, $59, $58, $58, $57, $57, $56, $56, $55, $55
    AD0B db $54, $54, $53, $53, $52, $52, $52, $51, $51, $50
    AD15 db $50, $4F, $4F, $4E, $4E, $4D, $4D, $4C, $4C, $4C
    AD1F db $4B, $4B, $4A, $4A, $49, $49, $48, $48, $47, $47
    AD29 db $47, $46, $46, $45, $45, $44, $44, $43, $43, $43
    AD33 db $42, $42, $41, $41, $40, $40, $3F, $3F, $3E, $3E
    AD3D db $3E, $3D, $3D, $3C, $3C, $3B, $3B, $3A, $3A, $39
    AD47 db $39, $38, $38, $38, $37, $37, $36, $36, $35, $35
    AD51 db $34, $34, $33, $33, $32, $32, $31, $31, $30, $30
    AD5B db $2F, $2F, $2E, $2D, $2D, $2C, $2C, $2B, $2B, $2A
    AD65 db $2A, $29, $28, $28, $27, $27, $26, $25, $25, $24
    AD6F db $23, $23, $22, $21, $21, $20, $1F, $1F, $1E, $1D
    AD79 db $1C, $1C, $1B, $1A, $19, $18, $18, $17, $16, $15
    AD83 db $14, $13, $12, $11, $10, $0E, $0D, $0C, $0B, $09
    AD8D db $08, $06, $05, $03, $01, $00, $00, $00, $00, $00
    AD97 db $00, $00, $00, $00, $00, $00, $FF, $FF, $FF, $FF
    ADA1 fill $FF, 29
    ADBE db $FD, $FB, $F9, $F7, $F5, $F4, $F2, $F0, $EE, $ED
    ADC8 db $EB, $EA, $E8, $E7, $E5, $E4, $E2, $E1, $E0, $DE
    ADD2 db $DD, $DC, $DB, $D9, $D8, $D7, $D6, $D5, $D4, $D3
    ADDC db $D2, $D1, $CF, $CE, $CD, $CC, $CB, $CA, $CA, $C9
    ADE6 db $C8, $C7, $C6, $C5, $C4, $C3, $C2, $C1, $C1, $C0
    ADF0 db $BF, $BE, $BD, $BC, $BC, $BB, $BA, $B9, $B8, $B8
    ADFA db $B7, $B6, $B5, $B5, $B4, $B3, $B2, $B2, $B1, $B0
    AE04 db $AF, $AF, $AE, $AD, $AD, $AC, $AB, $AB, $AA, $A9
    AE0E db $A9, $A8, $A7, $A6, $A6, $A5, $A5, $A4, $A3, $A3
    AE18 db $A2, $A1, $A1, $A0, $9F, $9F, $9E, $9D, $9D, $9C
    AE22 db $9B, $9B, $9A, $9A, $99, $98, $98, $97, $96, $96
    AE2C db $95, $95, $94, $93, $93, $92, $91, $91, $90, $90
    AE36 db $8F, $8E, $8E, $8D, $8C, $8C, $8B, $8B, $8A, $89
    AE40 db $89, $88, $87, $87, $86, $85, $85, $84, $83, $83
    AE4A db $82, $82, $81, $80, $80, $7F, $7E, $7E, $7D, $7C
    AE54 db $7B, $7B, $7A, $79, $79, $78, $77, $77, $76, $75
    AE5E db $74, $74, $73, $72, $71, $71, $70, $6F, $6E, $6E
    AE68 db $6D, $6C, $6B, $6A, $69, $69, $68, $67, $66, $65
    AE72 db $64, $63, $62, $61, $60, $5F, $5E, $5D, $5C, $5B
    AE7C db $5A, $59, $58, $57, $56, $54, $53, $52, $51, $4F
    AE86 db $4E, $4C, $4B, $49, $47, $46, $44, $42, $40, $3E
    AE90 db $3C, $39, $36, $34, $30, $2D, $29, $24, $1F, $18
    AE9A db $0F, $00, $00
    Happy New Year eveyone.
    Dec 2009
    So I suppose now that I have gotten to this point, I should ask the EFILive guy's what info do you need to start supporting these ECM's. I will do what I can to work tward that.
    Sorry sabercatpuck, you're on your own on this one, we are pretty much mapped out for 2010 with 'new' controllers. Going back to 68HC11 stuff does nothing for me, sorry.
    Dec 2009
    At least I know I won't be stepping on your toes since it would be bad of me to thieve your business on your own forum.
    There is some salivating going on on the Saturnfans forum for this though. of course most of them are thinking os mods and mpg gains rather than HP.
    I assume that means no hope for 2004+ 3800 Series III PCM's?
    I don't know about no hope, but the release of them would be met with 'custom OS' cries, much like what is happening with Tunercat, HPT, DHP and whoever else currently supports them. What GM has in there doesn't seem to be good enough for what people want to do with that engine.
    You did remind me though, we have all the read bootloaders done for those PCM's (like 3 years ago), I should put them out for BBR.
    Quote Originally Posted by sabercatpuck View Post
    Go for it, I hope you succeed in what you are trying to do. You should see if the DIYEFI forum is still going.
  9. #19
    I'm not quite sure what kind of Custom OS people want for it ; Personally, I'd love just read/flash (full/cal) and basic tuning. I'm probably going to be doing some kind of supercharged swap in an 04 Grand Prix GT around April/May, and while I can flash a GTP cal into the PCM with my Tech2, but if we just swap the motor or heads, the gear ration will be wrong.
    If you add the bootloader and want files, I have access to one, as well as 5 or 6 02-05 4-cyl PCM's that the tune tool doesn't know what to do with.
  10. #20
    Dec 2007
    Yes, Please...
    -Adam Chant
    Tune it or lose it!
    2007 Saturn SKY 2.4L Automatic - E67
    EFILive Tuned
  1. 2004 Saturn Ion Scanning??????
    By BlkMax in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: November 18th, 2011, 10:55 AM
  2. Replies: 65
    Last Post: January 18th, 2010, 12:58 AM
  3. 2003 h2 and 04 saturn ion
    By blackdeath in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2009, 05:09 PM
  4. GM to crack down on Aftermarket calibrated vehicles?
    By DrkPhx in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2008, 03:15 PM
  5. Finally got my first crack at BBL
    By TAQuickness in forum FlashScan V2 BB Logging
    Last Post: December 9th, 2007, 12:22 PM
