Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: 99 Saturn crack log
  1. #31
    Dec 2009
    This is bank 3, it resides on the flash from 18000 to 1ffff
  2. #32
    Dec 2009
    By the way, these are some of the numbers on the IC's on the board just in case it helps:
    185
    16196452
    e87j (this is the 68hc11F1)
    18391m64
    66285
    delco 466
    a8372y25
    39194
    delco 466
    a8393p53
    51862
    delco 466
    16132083
    a 9832 736 (date code?)
    m832316apa
    flash
    AN28f010 (the flash rom)
    185
    16185984
    2e79n (68hc56fn, the dlc I/O device)
    16132083
    a 9833 736 (date code?)
    m83309apa
    18412r31
    66285
    delco 466
    a8403m42
    51862
    delco
    05799
    t8383655
    466
  3. #33
    Dec 2009
    Well my agilent logicwave logic analyzers will hopefully show up tomorrow. Probably will take a bit to work the bugs out since they do not have cables (what can you expect for cheap ) but hopefully I can have them hooked up and reading by the end of the month. Then I should be able to start making heads and tails of the code. I think the biggest questionmark is really what do the tables mean (scaling etc) and what ends up in any given memory address. At some point I will have to figure out how to get the stuff out of the eeprom on the CPU as well.
  4. #34
    Default Hmmm, very intersting...
    Acquiring the Agilent is cool...
    I acquired an old HP (before Agilent) and an old Tektronix (I asked my work if I could have them since they were being thrown out, and my work said yes)...
    so now I need (for LS1):
    - to get the card out of a spare PCM,
    - a way to read the raw bin from it,
    - a 68332 disassembler (preferably free).
  5. #35
    Dec 2009
    Took a quick run arround the net and did not pull up a free dissasembler, IDA is supposed to be good for many processors, but it isn't free.
    BTW I do think I have a way of getting the stuff off of the eeprom, once I have the logicwave's hooked up, I just write a small section of code that will set the appropriate register bits then pick a spot and read and write them on the databus, the logic analyzer will pick up the code just fine. Eventually I should be able to do it with just mode $27 stuff I would think, but my early attempts to make that work have been less than fruitfull. At least I have made it past getting the seed/key pair though.
  6. #36
    Dec 2009
    Well I officially have the logic analyers up and working. Just need to make the connections and away I go.
  7. #37
    Dec 2009
    Well for those of you playing the home game I have some info from logic analyzer world. The major enhanced mode entry points. This is all in the 3rd upper memory block.
    10 $8F26
    12 $8FE8
    13 $9103
    14 $91e2
    17 $91F9
    18 $946d
    19 $964e
    20 $98Ac
    22 $98Dd
    23 $991c
    25 $9963
    27 $9971
    28 $99Fa
    29 $9A44
    2a $9A42
    2b $9C28
    2c $9C7c
    31 $9DF6
    32 $9DF6
    33 $9DF6
    34 $9E44
    35 $9EA6
    3b $A4B6
    3c $A4B6
    3f $A8Cd
    The jump table that access these actually shows 4 digits lower, but when the indirect call is made it adds 4 to the address.
  8. #38
    Oct 2010
    Have you gotten any further with this?
  9. #39
    Dec 2009
    I have been off on honeydo projects for awhile. If things go relatively well this winter I am hoping to have a chance to go at it some more.
  10. #40
    Any chance the honeydo projects have subsided?
  1. 2004 Saturn Ion Scanning??????
    By BlkMax in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: November 18th, 2011, 10:55 AM
  2. Replies: 65
    Last Post: January 18th, 2010, 12:58 AM
  3. 2003 h2 and 04 saturn ion
    By blackdeath in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2009, 05:09 PM
  4. GM to crack down on Aftermarket calibrated vehicles?
    By DrkPhx in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2008, 03:15 PM
  5. Finally got my first crack at BBL
    By TAQuickness in forum FlashScan V2 BB Logging
    Last Post: December 9th, 2007, 12:22 PM
