The goal is to find how much Idle Airflow is required for each of the ECT Values.
I might suggest you repeat the RAFIG once you have it figured out. So far your values seem unusually large.
To get a good RAFIG your VE Table and MAF Calibration Table should be as accurate as possible. If they are not correct, what is happening is that your Short and Long-term Idle trims will have a very large correction value when you do RAFIG.
RAFIG is generally more useful when your VE Table and MAF airflow is nailed down.
well my cars tune isnt complete. mostly idle issues. this is why im trying to get the rafpn down first and the rafig. ass ssdemon says to do. then ill work on the idle dipping down to much. its funny cause right now when my idle dips down in park when the car is in operating temps, and if i play with the idle and raise the idle to 900 instead of 800 it wont dip anymore. but i dont believe this is the best way to fix this. this is why im trying ss demons writeup.
Can you post a screen shot of the actual values in Airflow tables (Metric) from the tune itself? What are the details of the setup? I have the same MAP setup and when I view the log, it shows -.2.61 gm/s (104-212 F) as an average which is not that unusual considering you're trying to drop the idle rpm 100 rpms. Depending on the size of the cam and tranmission (auto or manual) that usually takes some time and patience to nail it.
BTW - You can change the values in the MAP to Metric by clicking Edit map properties with the MAP displayed and change the Parameter by selecting the metric version of the parameter. Or you can change the properties of the Airflow table itself in the tuning software. Either way, they should match for simplicity sake.
Post your tune.
Here it is
That is alot of airflow in the Desired Airflow Table and some pretty high spark values at idle. The MAF table is kind of tweaked. Is this a stroker motor? What are the details of your setup?
