Results 1 to 10 of 14
Thread: Flashing different OS?
    Lifetime Member driver456's Avatar
    Default Flashing different OS?
    I have a 99 Chevy Silverado w/09379910 OS pcm.Can I full flash a different OS into it so I can use the COS#5? I have an extra 99-02 pcm just in case.I just don't remember if I could do that.................Paul
    You need to be running the 02 F Body OS before you can upgade to COS5. Once you have copied all of your tables over you can full flash that OS in, then upgrade to COS5.
    Aahhh OK.Thank you.................Paul
    OK I did a full flash and the truck does not start.I'm getting "U1000 Class 2 data link $1A Transfer Case Shift Control Module" Now what................Paul
    Aug 2008
    What file did you flash into PCM? Was it a truck file or a F-body file?
    Find a truck file that has OS 12212156 or 12202088 so you can use the COS's....
    FLASHSCAN V2 & AUTOCAL
    OK I'll try that,Thanks................Paul
    Quote Originally Posted by GAMEOVER View Post
    Thanks man that worked.Started right up I used an 02 silverado w/12212156 OS.I also put in the BCC code.I did not do that on the last one.I don't know if that had anything to do with it.Any way's it starts.Thanks again
    Aug 2008
    Cool....
    Be sure to read this.
    COS5:
    showthread.php?t=2599
    showthread.php?t=2270
    Well its back again,Same problem.Any idea's?
  1. E38 Flashing tips.....
    By swingtan in forum E37, E38 & E67 PFI ECM's
    Last Post: June 2nd, 2011, 02:15 AM
  2. Flashing ECM Alone?
    By Nemo in forum General (Diesel)
    Last Post: April 12th, 2010, 09:18 AM
  3. re-flashing
    By s10mods in forum General (Petrol, Gas, Ethanol)
    Last Post: September 18th, 2007, 10:39 PM
  4. flashing MIL?
    By Thimble in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2007, 01:44 PM
