Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Adding O2's
  1. #21
    Nov 2006
    It's been a while since I tried this but IIRC
    {B4206} Enabled is just CL w/o LTFTs
    {B3605} won't come into play even if PE is off.
    LC-1 WBO2
  2. #22
    Junior Member Frost's Avatar
    Nov 2009
    There is a lot of EFIL specific terminology here that I don't know... The OEM PCM for GenIII can run STFTs in OL (off by OEM default), STFTs, and LTFTs. My suggestion was simply to use STFTs and not LTFTs. If the MAF and VE are close, the driver should not be able to distinguish between the 2 closed loop fuel approaches.
  3. #23
    Jul 2008
    l WeathermanShawn has a tough job there in Co. where people (not just tuners) depend on the weather report, my hat off to
    you...
    Thanks for the 'shout out' Joecar. Yes, Colorado is a beautiful state, but can be a tough place to forecast weather. Thanks for recognizing the challenge.
  4. #24
    B4206 description says:
    "If this parameter is enabled then O2 feedback (STFT) will be used with the Open Loop table."
  5. #25
    Nov 2009
    Makes more sense read like that... In HPT the description is just STFTs active in OL.... which seems to be contradictory at face value This is the same item that I mentioned in my post above (and said off by OEM default but was referring to cars not trucks...).
  6. #26
    Oct 2007
    just do OLSD and be done with it
    01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
  7. #27
    jsm00z28ss,
    Is there any particular reason why you want to put the O2's back in...?
  8. #28
    Dec 2009
    Just something I wanted to do to see if I could and to see how the motor would react. I also want to see if there is any way to improve upon what I have.
  9. #29
    Ok we were just curious... in case you had seen some problem.
  1. Adding logs together?
    By hquick in forum General
    Last Post: July 21st, 2010, 02:42 AM
  2. Adding headers + O2
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: July 28th, 2009, 10:12 AM
  3. COS#3 adding timing
    By minytrker in forum Custom Operating Systems
    Last Post: November 26th, 2008, 05:39 AM
  4. Adding fuel
    By Lennart in forum General (Diesel)
    Last Post: January 18th, 2006, 03:43 PM
