Results 1 to 8 of 8
Thread: LTFT tuning questions
    Jul 2009
    Default LTFT tuning questions
    Just a few questions with LTFT tuning
    I have been following the forum for LTFT tuning and have set the O2 switch point all to 450mv
    1. I want to know when i have finished do I set the O2 shitch point back to the
    original settings or leave them at 450 mv
    2. What is the purpose of setting the O2 switch point to 450mv, What is the problem with tuning without changing
    the O2 awitch point
    3. After tuning using this method i find the the VE table cell numbers are very low is this normal
    Nov 2006
    Are all the VE table cell numbers low or just the low RPM/MAP parts?
    Is AFR lean at cold start?
    LC-1 WBO2
    Jul 2009
    The cell numbers are very low
    it is rich on warn up
    i have put the 02 switch points back to original.
    Should i have kept them all at the 450 mv as i that is where i did my tuning
    now when i look at the average LTFT they are all alound 1.10
    Jul 2009
    when i say the cell numbers are low i mean the ones i have changed using this method
    Nov 2006
    After applying LTFT 1.1, you should have higher VE values than OL.
    OL fueling can be controlled by changing {B3605}.
    Are you reseting LTFTs after making changes?
    What is the PID formula and filter you are using for this?
    LC-1 WBO2
    Jul 2009
    Thanks for being patient but i think i am not explaining myself well
    I followed the prosedure for LTFT tuning and all the cells went to 0 as expected
    then i changed the 02 switch point back to the original settings I am not sure if this is what i was supose to do?
    At this point i did another log for curiousity and found all the cells i hit were reading 1.10
    Should i have left the 02 switch point at 450mv?
    What is the reason for setting the 02 switch point to 450mv or can i tune with the original 02 switch point settings
    I am just trying to understand how it works
    Nov 2006
    I leave them @ 450mV
    450mV is the "universal" SP for /NBO2s and
    the newer GM OS' have a flat 450mV SP as well,
    that is my reasoning for flat SPs.
    The stock settings are lower than 450mV, right?
    I suggest leaving them where you tuned with or
    changing them slightly after wards too much will throw off AFR/LTFTs
    Lower switch points=leaner
    Higher switch points=richer
    LC-1 WBO2
    Jul 2009
    Good info thanks for that
  1. LTFT Tuning?
    By stevedarman in forum Gen III V8 Specific
    Last Post: October 8th, 2009, 05:38 AM
  2. Newbe with Questions on autove and LTFT
    By Johno in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2009, 07:03 PM
  3. MAF tuning via LTFT/STFT?
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: April 4th, 2007, 06:25 AM
  4. tuning VE and PE...my LTFT's are high..up to 20
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2005, 09:54 AM
  5. SD Tuning a 98-00 Fbod w/ LTFT's
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: January 26th, 2005, 07:56 AM
