Results 1 to 4 of 4
Thread: EFI Live V4 xml file for 94 Regal 3800
    Dec 2009
    Default EFI Live V4 xml file for 94 Regal 3800
    Hi I've just started using EFI Live V4 and have a question about the xml files that are included in the package. I've got a 94 Regal 3800 and the closest xml file I could find to my vehicle was the "95 pontiac vin K.xml" file. This is for the 95 bonneville which is not a W body but uses the same 3800 series 1 as my regal. My question is can I use this file to pull DTC from the car's computer. It SEEMS to work but I can't tell if this is 100% accurate since the xml file was not made specifically for my vehicle. Also does anyone know where I can get a 94 W body 3800 xml file? There are 94-95 w body xml files included but they're for the 3.4 DOHC v6. Thanks for your help.
    Oct 2004
    It is important to note that EFILive does not develop, maintain or support any definitions. Available definitions have been provided by customers and are made available as a courtesy only.
    We probably couldn't give a definitive answer in regards to the accuracy or completeness of the file you are currently using for your actual vehicle.
    If you can please send your full VIN through to support@efilive.com, what we might be able to find is a specification file which you could use to create the XML from.
    Andrew
    EFILive Crew
    Dec 2009
    Thanks Andrew, I'll email my vin (2G4WB55LXR1------) to that address now.
    Last edited by Tordne; December 29th, 2009 at 07:41 AM. Reason: Removed VIN sequence
    Oct 2004
    You've got mail
    Andrew
    EFILive Crew
  1. EFI Live File Section - Share your tunes!!!
    By Black02SS in forum Please Read First
    Last Post: March 11th, 2024, 11:39 PM
  2. HELP!!! Converting Efi Live to HPTuners file!
    By 06x6spdGTO in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2010, 12:46 AM
  3. 03 Impala V6 3800
    By 06-6.0 SierraHD in forum General (Petrol, Gas, Ethanol)
    Last Post: February 14th, 2009, 12:53 AM
  4. 3800 series II
    By DURAtotheMAX in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2007, 05:06 PM
  5. 3800 L67
    By RUTAN TA in forum General (Petrol, Gas, Ethanol)
    Last Post: October 5th, 2007, 02:14 PM
