Results 1 to 10 of 11
Thread: why does this happen alot? -log reading prob
    Senior Member whackem04's Avatar
    Apr 2009
    Default why does this happen alot? -log reading prob
    does this happen to anyone else? it does it to lots of logs.
    01 GMC Sierra 1500 SLE 5.3 cam swap
    Tuned by ME (COS 5 - running strong and smooth)
    Jan 2007
    Are one of your number keys stuck down? Looks like it's 'marking' a point in the log.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Apr 2009
    no all keys are fineeeeeeeeeeeeeeeeee.
    Apr 2009
    when i open a log, it doesnt display all the pids i know it recorded.
    Oct 2004
    Check your software version, and also the firmware if you are using FlashScan V2.
    Software should be at least 7.5.5 Build 88
    FlashScan V2 firmware should be at least 2.06.12
    This was a problem a while back...
    Andrew
    EFILive Crew
    Oct 2004
    Oh. And the PIDs should all show on the F9 Data tab (not necessarily on the graphs/gauges unless you have specifically changed them to show a different PID.
    Andrew
    EFILive Crew
    Nov 2006
    Quote Originally Posted by whackem04 View Post
    It looks like the E key is stuck.
    LC-1 WBO2
    Apr 2009
    7.5.6 build 99
    Apr 2009
    does anyone else have a problem looking at logs at all or is it me?
    I've seen that before in my logs, but it's been a while, and it didn't happen often.
  1. What will happen?
    By ferramento in forum Allison 5 & 6 Speed
    Last Post: February 26th, 2010, 11:27 AM
  2. Alot, Alittle, Close Enough, etc
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: January 11th, 2008, 02:01 AM
  3. Reading an E38 / E67 ECM
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: June 6th, 2007, 07:02 PM
  4. 2002-2005 cals have alot more things added to them in latest update :)
    By wait4me in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: March 30th, 2007, 11:16 AM
  5. Reading the P12 PCM
    By GMPX in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 18th, 2007, 10:48 PM
