It might be the old "log full of notes" issue that has been around for quite a while. Try shutting down all other applications and then opening the log file and see what happens. If it works OK, then see if you can fine which application is causing the problem. Things like VNC Viewer and Windows DRP Viewer seem to cause havoc with opening logs. Normal symptoms are...
- log full of notes.
- missing PID's.
- log length shorter than expected.
- log data showing random values.
Simon.
