Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: failed flash
    Senior Member pdasterly's Avatar
    Oct 2007
    Default failed flash
    Pcm in unknown state unable to start car, i need some help
    09:49:17.587: Scanning for EFILive FlashScan V2 USB
    09:49:17.603: Autodetect interface ...
    09:49:19.412: Interface not detected
    09:49:20.083: Scanning for EFILive FlashScan V2 HAPI
    09:49:20.099: Autodetect interface ...
    09:49:20.270: Interface firmware version: 2.6.21
    09:49:20.270: Connection to [FSV2] interface is OK
    09:49:20.302: Interface firmware model: FSV2
    09:49:20.317: Interface firmware version: 2.6.21
    09:49:20.348: Interface firmware date: Dec 20, 2009
    09:49:20.364: FlashScan serial number: 003642841043
    09:49:20.380: FlashScan license number: 003642841043
    09:49:20.411: Disconnecting ...
    09:49:21.144: CAN-VPW Bridge Deactivated
    09:49:21.160: Disconnected
    09:49:21.815: Scanning for EFILive FlashScan V2 USB
    09:49:21.830: Autodetect interface ...
    09:49:23.656: Interface not detected
    09:49:24.342: Scanning for EFILive FlashScan V2 HAPI
    09:49:24.358: Autodetect interface ...
    09:49:24.529: Interface firmware version: 2.6.21
    09:49:24.545: Connection to [FSV2] interface is OK
    09:49:24.560: CAN-VPW Bridge Activated
    09:49:24.654: Current protocol set to: "SAE J1850 VPW"
    09:49:24.670: Autodetect PCM...
    09:49:24.716: Connection to PCM is OK
    09:49:24.732: Autodetect TCM...
    09:49:25.777: TCM not detected.
    09:49:25.793: Current protocol: "SAE J1850 VPW"
    09:49:25.840: Interface firmware model: FSV2
    09:49:25.855: Interface firmware version: 2.6.21
    09:49:25.886: Interface firmware date: Dec 20, 2009
    09:49:25.902: FlashScan serial number: 003642841043
    09:49:25.918: FlashScan license number: 003642841043
    09:49:26.994: Autodetect interface ...
    09:49:27.041: Interface firmware version: 2.6.21
    09:49:27.041: Connection to [FSV2] interface is OK
    09:49:27.056: Autodetect PCM...
    09:49:28.133: PCM not detected.
    09:49:29.194: Getting status...
    09:49:29.740: Status: Calibration missing.
    09:49:31.757: Bootloader version: LS1B_v1.7C (08DC-9623)
    09:49:31.773: Preparing PCM for reflash...
    09:49:31.804: PCM reports "Not secured!"
    09:49:31.819: Initializing PCM...
    09:49:32.085: Initializing PCM, step 1 of 4
    09:49:32.085: Initializing PCM, step 2 of 4
    09:49:32.350: Initializing PCM, step 3 of 4
    09:49:32.865: Initializing PCM, step 4 of 4
    09:49:37.888: No response from PCM. Retry 1...
    09:49:38.013: PCM reports "Not secured!"
    09:49:38.028: Initializing PCM...
    09:49:38.293: Initializing PCM, step 1 of 4
    09:49:38.293: Initializing PCM, step 2 of 4
    09:49:38.559: Initializing PCM, step 3 of 4
    09:49:39.073: Initializing PCM, step 4 of 4
    09:49:44.097: No response from PCM. Retry 2...
    09:49:45.468: PCM is in an unknown state.
    09:49:47.605: Clear emisison related DTCs...
    09:49:48.666: Autodetect interface ...
    09:49:48.697: Interface firmware version: 2.6.21
    09:49:48.713: Connection to [FSV2] interface is OK
    09:49:48.728: Autodetect PCM...
    09:49:48.744: Connection to PCM is OK
    09:49:49.274: Clear DTCs for all modules...
    09:49:49.555: Disconnecting ...
    09:49:50.288: CAN-VPW Bridge Deactivated
    09:49:50.304: Disconnected
    09:49:50.320: Data transfer was interrupted.
    09:49:55.572: Done!
    09:50:12.416: Scanning for EFILive FlashScan V2 USB
    09:50:12.432: Autodetect interface ...
    09:50:14.242: Interface not detected
    09:50:14.912: Scanning for EFILive FlashScan V2 HAPI
    09:50:14.928: Autodetect interface ...
    09:50:15.100: Interface firmware version: 2.6.21
    09:50:15.100: Connection to [FSV2] interface is OK
    09:50:15.131: Interface firmware model: FSV2
    09:50:15.162: Interface firmware version: 2.6.21
    09:50:15.178: Interface firmware date: Dec 20, 2009
    09:50:15.193: FlashScan serial number: 003642841043
    09:50:15.224: FlashScan license number: 003642841043
    09:50:15.256: Disconnecting ...
    09:50:15.989: CAN-VPW Bridge Deactivated
    09:50:16.004: Disconnected
    09:50:16.660: Scanning for EFILive FlashScan V2 USB
    09:50:16.675: Autodetect interface ...
    09:50:18.469: Interface not detected
    09:50:19.140: Scanning for EFILive FlashScan V2 HAPI
    09:50:19.156: Autodetect interface ...
    09:50:19.327: Interface firmware version: 2.6.21
    09:50:19.327: Connection to [FSV2] interface is OK
    09:50:19.343: CAN-VPW Bridge Activated
    09:50:19.421: Current protocol set to: "SAE J1850 VPW"
    09:50:19.436: Autodetect PCM...
    09:50:19.468: Connection to PCM is OK
    09:50:19.483: Autodetect TCM...
    09:50:20.528: TCM not detected.
    09:50:20.544: Current protocol: "SAE J1850 VPW"
    09:50:20.575: Interface firmware model: FSV2
    09:50:20.591: Interface firmware version: 2.6.21
    09:50:20.606: Interface firmware date: Dec 20, 2009
    09:50:20.638: FlashScan serial number: 003642841043
    09:50:20.653: FlashScan license number: 003642841043
    09:50:21.730: Autodetect interface ...
    09:50:21.776: Interface firmware version: 2.6.21
    09:50:21.776: Connection to [FSV2] interface is OK
    09:50:21.792: Autodetect PCM...
    09:50:22.853: PCM not detected.
    09:50:23.914: Getting status...
    09:50:24.460: Status: Calibration missing.
    09:50:26.012: Bootloader version: LS1B_v1.7C (08DC-9623)
    09:50:26.022: Preparing PCM for reflash...
    09:50:26.063: PCM reports "Not secured!"
    09:50:26.063: Initializing PCM...
    09:50:26.328: Initializing PCM, step 1 of 4
    09:50:26.328: Initializing PCM, step 2 of 4
    09:50:26.594: Initializing PCM, step 3 of 4
    09:50:27.093: Initializing PCM, step 4 of 4
    09:50:32.116: No response from PCM. Retry 1...
    09:50:32.241: PCM reports "Not secured!"
    09:50:32.256: Initializing PCM...
    09:50:32.522: Initializing PCM, step 1 of 4
    09:50:32.522: Initializing PCM, step 2 of 4
    09:50:32.787: Initializing PCM, step 3 of 4
    09:50:33.286: Initializing PCM, step 4 of 4
    09:50:33.738: Initializing bootloader...
    09:50:34.175: Initializing bootloader, step 1 of 5
    09:50:34.846: Initializing bootloader, step 2 of 5
    09:50:36.952: Initializing bootloader, step 3 of 5
    09:50:37.639: Initializing bootloader, step 4 of 5
    09:50:38.341: Initializing bootloader, step 5 of 5
    09:50:38.855: PCM ready for reflashing.
    09:50:38.855: Request GM operating system...
    09:50:38.887: GM operating system: 9360361
    09:50:39.511: Request serial number...
    09:50:39.589: Serial number: 1DG0FCH19147
    09:50:40.509: Erasing PCM flash memory... (please wait up to 120 seconds)
    09:50:41.507: PCM flash memory erased OK
    09:50:41.741: Reflashing PCM's memory...
    09:59:03.346: Total time: 08:21
    09:59:03.361: Data compression achieved: 8.9%
    09:59:08.509: PCM is in an unknown state.
    09:59:10.647: Clear emisison related DTCs...
    09:59:11.723: Autodetect interface ...
    09:59:11.770: Interface firmware version: 2.6.21
    09:59:11.785: Connection to [FSV2] interface is OK
    09:59:11.785: Autodetect PCM...
    09:59:11.832: Connection to PCM is OK
    09:59:12.363: Clear DTCs for all modules...
    09:59:12.659: Disconnecting ...
    09:59:13.392: CAN-VPW Bridge Deactivated
    09:59:13.392: Disconnected
    09:59:13.408: Reflash failed.
    09:59:42.945: Done!
    1998 Camaro Z28, forged ls2 sts turbo GtsT76, fmic
    1999 Firebird, forged ls1 procharger p1sc ls9 cam fmic
    1981 El Camino, 5.3 LSX carb, msd 6010
    2011 2SS
    Oct 2004
    Something is really not right for you. I suspect either:
    - you have a dodgy PCM. There are no response from PCM and retires in the above which are irregular.
    - questionable electrical connection from the ODBII port to the PCM. Are you able to try flashing that PCM on a bench harness?
    If you were doing a calibration only flash the bootloaders would not have been updated so the flash should not have bricked the controller.
    Andrew
    EFILive Crew
    Oct 2004
    Actually I notice also that your sig has 98Z28, yet the OS reported is 9360361 which is the 99+ LS1 PCM?
    Andrew
    EFILive Crew
    Nov 2006
    Were you the guy that was having half hour reflashes?
    LC-1 WBO2
    Oct 2004
    Yeah, same person. That log is the same as posted in the other thread.
    Interested in the result of the 98Z28 and 99+ PCM question. I definitely am not suspecting an EFILive hardware or software here, but of course am also not ruling it out absolutely.
    Andrew
    EFILive Crew
    Nov 2006
    So this is a converted PCM?
    A '99 .tun in a '98 PCM might cause some problems.
    I noticed a lot of extra wiring in the sig maybe a low battery or
    noise in OBD port causing flash issues.
    LC-1 WBO2
    Oct 2004
    Would definately be interesting to see it flashed on a bench harness.
    Andrew
    EFILive Crew
    Oct 2007
    yes my flashes are taking too long, then failing. My camaro is a 98 and is currently being updated to 2002 harness and pcm, but the firebird is a 99.
    2011 2SS
    Oct 2004
    Just to remove any confusion this is the PCM in the 98 (updated) or 99?
    Andrew
    EFILive Crew
    Oct 2007
    no, the firebird is all 99
    2011 2SS
  1. failed flash
    By 69camaro5speed in forum Allison 5 & 6 Speed
    Last Post: January 8th, 2009, 12:58 PM
  2. Help flash memory test failed
    By modpcm in forum FlashScan V2 BB Logging
    Last Post: June 13th, 2008, 09:33 AM
