Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 49
Thread: failed flash
  1. #11
    Oct 2004
    Ok, so it is the 99 that has this issue.
    I'd really want to see this PCM flashed out of the vehicle on a bench harness. Any chance of that happening (do you know anyone with a harness)?
    Or perhaps send the PCM to Ira at Fish Tuning so he can test on the bench.
    Andrew
    EFILive Crew
  2. #12
    Senior Member pdasterly's Avatar
    Oct 2007
    pcm was able to flash before motor swap
    1998 Camaro Z28, forged ls2 sts turbo GtsT76, fmic
    1999 Firebird, forged ls1 procharger p1sc ls9 cam fmic
    1981 El Camino, 5.3 LSX carb, msd 6010
    2011 2SS
  3. #13
    Default 1999 Firebird
    09:49:31.819: Initializing PCM...
    09:49:32.085: Initializing PCM, step 1 of 4
    09:49:32.085: Initializing PCM, step 2 of 4
    09:49:32.350: Initializing PCM, step 3 of 4
    09:49:32.865: Initializing PCM, step 4 of 4
    09:49:37.888: No response from PCM. Retry 1...
    09:49:38.013: PCM reports "Not secured!"
    09:49:38.028: Initializing PCM...
    09:49:38.293: Initializing PCM, step 1 of 4
    09:49:38.293: Initializing PCM, step 2 of 4
    09:49:38.559: Initializing PCM, step 3 of 4
    09:49:39.073: Initializing PCM, step 4 of 4
    09:49:44.097: No response from PCM. Retry 2...
    09:49:45.468: PCM is in an unknown state.
    At this point try: disconnect battery, leave it off for a few minutes, then reconnect battery.
    With the scantool do you see any DTC's from any of the modules on the bus (PCM, EBCM/ABS, SIR, IPC)...?
  4. #14
    Can you test your V2 on another vehicle (F-car if possible), try to read it's PCM.
  5. #15
    Oct 2007
    I dont have another vehicle, camaro is in pieces as of now
    2011 2SS
  6. #16
    Can you read the 1999's PCM...?
  7. #17
    How "charged" is the battery in the 1999 Firebird...?
  8. #18
    Oct 2007
    yes, i can read the pcm, battery is charged(optima red top)
    2011 2SS
  9. #19
    Oct 2007
    13:24:28.443: Scanning for EFILive FlashScan V2 USB
    13:24:28.459: Autodetect interface ...
    13:24:30.253: Interface not detected
    13:24:30.908: Scanning for EFILive FlashScan V2 HAPI
    13:24:30.923: Autodetect interface ...
    13:24:31.095: Interface firmware version: 2.6.21
    13:24:31.095: Connection to [FSV2] interface is OK
    13:24:31.111: Interface firmware model: FSV2
    13:24:31.126: Interface firmware version: 2.6.21
    13:24:31.142: Interface firmware date: Dec 20, 2009
    13:24:31.142: FlashScan serial number: 003642841043
    13:24:31.157: FlashScan license number: 003642841043
    13:24:31.173: Disconnecting ...
    13:24:31.906: CAN-VPW Bridge Deactivated
    13:24:31.906: Disconnected
    13:24:32.546: Scanning for EFILive FlashScan V2 USB
    13:24:32.561: Autodetect interface ...
    13:24:34.355: Interface not detected
    13:24:35.011: Scanning for EFILive FlashScan V2 HAPI
    13:24:35.026: Autodetect interface ...
    13:24:35.198: Interface firmware version: 2.6.21
    13:24:35.198: Connection to [FSV2] interface is OK
    13:24:35.213: CAN-VPW Bridge Activated
    13:24:35.276: Current protocol set to: "SAE J1850 VPW"
    13:24:35.276: Autodetect PCM...
    13:24:35.291: Connection to PCM is OK
    13:24:35.307: Autodetect TCM...
    13:24:36.337: TCM not detected.
    13:24:36.337: Current protocol: "SAE J1850 VPW"
    13:24:36.368: Interface firmware model: FSV2
    13:24:36.383: Interface firmware version: 2.6.21
    13:24:36.383: Interface firmware date: Dec 20, 2009
    13:24:36.399: FlashScan serial number: 003642841043
    13:24:36.415: FlashScan license number: 003642841043
    13:24:37.475: Autodetect interface ...
    13:24:37.507: Interface firmware version: 2.6.21
    13:24:37.507: Connection to [FSV2] interface is OK
    13:24:37.507: Autodetect PCM...
    13:24:38.567: PCM not detected.
    13:24:39.613: Getting status...
    13:24:40.143: Status: Calibration missing.
    13:24:42.638: Bootloader version: LS1B_v1.7C (08DC-9623)
    13:24:42.638: Preparing PCM for reflash...
    13:24:42.654: PCM reports "Not secured!"
    13:24:42.669: Initializing PCM...
    13:24:42.935: Initializing PCM, step 1 of 4
    13:24:42.935: Initializing PCM, step 2 of 4
    13:24:43.184: Initializing PCM, step 3 of 4
    13:24:43.683: Initializing PCM, step 4 of 4
    13:24:44.448: Initializing bootloader...
    13:24:44.900: Initializing bootloader, step 1 of 5
    13:24:45.571: Initializing bootloader, step 2 of 5
    13:24:46.258: Initializing bootloader, step 3 of 5
    13:24:46.928: Initializing bootloader, step 4 of 5
    13:24:47.599: Initializing bootloader, step 5 of 5
    13:24:48.114: PCM ready for reflashing.
    13:24:48.114: Request GM operating system...
    13:24:48.145: GM operating system: 9360361
    13:24:48.769: Request serial number...
    13:24:48.847: Serial number: 1DG0FCH19147
    13:24:49.736: Erasing PCM flash memory... (please wait up to 120 seconds)
    13:24:50.688: PCM flash memory erased OK
    13:24:50.906: Reflashing PCM's memory...
    13:32:51.688: Total time: 08:00
    13:32:51.688: Data compression achieved: 8.9%
    13:32:56.821: PCM is in an unknown state.
    13:32:58.958: Clear emisison related DTCs...
    13:33:00.003: Autodetect interface ...
    13:33:00.050: Interface firmware version: 2.6.21
    13:33:00.050: Connection to [FSV2] interface is OK
    13:33:00.065: Autodetect PCM...
    13:33:00.097: Connection to PCM is OK
    13:33:00.627: Clear DTCs for all modules...
    13:33:00.908: Disconnecting ...
    13:33:01.625: CAN-VPW Bridge Deactivated
    13:33:01.641: Disconnected
    13:33:01.641: Reflash failed.
    13:33:05.755: Done!
    2011 2SS
  10. #20
    Oct 2004
    Quote Originally Posted by pdasterly
    So the PCM of the 1999 PCM can be read with FlashScan successfully? Can you please read the 1999 PCM now and email the .tun file to support@efilive.com? Please also advise how long it takes to perform the PCM read.
    Really scratching head that you can read but not flash .
    Andrew
    EFILive Crew
  1. failed flash
    By 69camaro5speed in forum Allison 5 & 6 Speed
    Last Post: January 8th, 2009, 01:58 PM
  2. Help flash memory test failed
    By modpcm in forum FlashScan V2 BB Logging
    Last Post: June 13th, 2008, 10:33 AM
