got it working finally
1998 Camaro Z28, forged ls2 sts turbo GtsT76, fmic
1999 Firebird, forged ls1 procharger p1sc ls9 cam fmic
1981 El Camino, 5.3 LSX carb, msd 6010
2011 2SS
Please describe what the issue was and the resolution for the benefit of all. This has been a most peculiar incident! Are the flash times normal now as well?
Andrew
EFILive Crew
i did a full reflash, after about the fourth try it went thru. Time was approx. 10 mins
2011 2SS
Something must have gotten itself in a knot and maybe now it's reset itself...
When you now read the PCM how long does it take...?
When you now do a cal-only flash how long does it take...?
I suspect there may have been something going on on the serial bus... do you get any DTC's (Uxxxx, Bxxxx, Cxxxx)...?
two minutes to read
2011 2SS
Please try and find someone with a bench harness that you8 can try reading and flashing on. We are not having any such issues with other customers, so that tends to place the porblem wither with the PCM itself, or the connection between it and the OBDII port in the vehicle.
Andrew
EFILive Crew
flash failing again
2011 2SS
Have you done a flash of that ECM on a bench harness yet? There is really little point posting continued failures until we can determine absolute that there is no issue with that ECM out of the vehicle. There are no outstanding/known issues flashing or reading LS1 PCM controllers so we do not believe there to be a fault with the EFILive software or FlashScan.
Andrew
EFILive Crew
where can i buy a bench harness?
2011 2SS
