Results 1 to 9 of 9
Thread: Interfacing OBD-1 to RS232C (via MAX232)
    New Member markrbarker's Avatar
    Dec 2009
    Default Interfacing OBD-1 to RS232C (via MAX232)
    Hi, I've searched around the Forum for quite a while, but I hadn't been able to find an answer, so here I am asking for help please. I'm a newbie.
    EFILive Eval Version, Win98, laptop pc c/w serial port
    Question: Is there a schematic available to make an interface between OBD-1 and a standard RS232 port?
    I understand a MAX232 is involved, that's OK, but I'm not completely understanding a loopback function going on that's required by EFILive, otherwise I would use this interface as a basis: http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm
    I can see from the above circuit a loopback going on at pin 'M'
    Is this circuit suitable ?
    Or should I really ought to be trying to buy this hardware from EFILive online store? :-)
    Hi Mark,
    I moved this to the V4 (OBD-I) section.
    I pm'd Tech Support for more info.
    Joe
    Oct 2004
    The link you posed (http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm) is correct, and is actually noted on the EFILive V4 product page on our website
    We also recommend this cable (http://www.moates.net/product_info.p...roducts_id=127) from one of our resellers, Moates Ware (maker of the RoadRunner PCM).
    Andrew
    EFILive Crew
    Dec 2009
    Many thanks for link for recommended cable (http://www.moates.net/product_info.p...roducts_id=127) I see it's got a mode selector '10K' switch included, and it's a USB interface which is great for laptops without COM ports as many are nowdays.
    But I'm afraid I couldn't wait for one of these to be mailed to me, so yesterday I'd built myself a cable on a bit of matrix board, based on the above circuit. The EFILive software seems quite happy with it, there are no loopback errors.
    I'm having trouble now with missing and/or incorrect data, I think might be a configuration error in the program maybe? I can detect car's ECU data telemetry (as far as I can tel) but there is a complete absence O2 signal displayed anywhere. I measure the mV accross the O2 sensor, it's there OK. I've also tried injecting a 500 mV signal across the O2 sensor itself, it's not picked up. Maybe the wrong TM byte is being addressed.
    Also engine rpm indicator (dashboard) has a large error:
    actual vs indicated
    500 821
    800 822
    1000 823
    2000 827
    3000 832
    Another thing I'm missing is interrogating DTC's. I believe they are retrieved in real time via the 'get engine data' macro
    But apart from that it's fine...
    Car's a UK Daewoo Lanos 1997
    Oct 2004
    Are you using the evaluation version (or the full version)? The evaluation version has some limitation (like not being able to save logs, showing limited DTC codes and logging restricted PIDs etc). I would not expect this necessarily to effect data accuracy however.
    Where has the vehicle definition you are using come from (i.e. is it known to be accurate for your vehicle)?
    If you can send your full VIN through to support@efilive.com I can see if we have a datastream specification file I can send you to aid with making an accurate vehicle definition?
    Andrew
    EFILive Crew
    Lifetime Member JezzaB's Avatar
    Nov 2006
    I believe there is an error in the TechEdge diagram. One of the diodes is around the wrong way (D3)
    Dec 2009
    If I remember rightly it came already bundled with the Eval version software. I didn't have to look for any separate definition files.
    Yes, will do, thank you :-)
    Dec 2009
    It looks to me like the pin M data is bi-directional wired-or (active low). Maybe an open-collector is at the ECU end, and the MAX232 pin 12 / D3 is a psuedo- open collector? If this is the case, I expect D3 to be correct polarity.
    Oct 2004
    Got the VIN. Sorry I hadn't noticed in a post above that your vehicle is a 1997. The data we have only goes through to 1995, so I don't have anything I can send you sorry.
    Andrew
    EFILive Crew
  1. New Innovate LM2 interfacing with EFI live?
    By 9secVette in forum Conversions / Aftermarket Parts
    Last Post: May 27th, 2010, 10:00 AM
  2. Problems with communicating efilive to max232
    By jnedmonds in forum EFILive V4
    Last Post: February 21st, 2006, 11:23 PM
