Thread: 5.3 liter 2002 suburban
    Aug 2008
    Default 5.3 liter 2002 suburban
    I'm not sure what PID list to log this truck with.. Was thinking it might be a LS based engine, But it also is a Vortec i believe..
    The truck just doesnt have the power that it used to... Atall. It throws the SES light everyday and I just clear that out with pedals while its off. Just trying to find out whats goin on wiht the old thing
    Aug 2008
    anybody?
    LS1_B is the PID list.
    There could be a lot of reasons why there is a power loss, whats the DTC code?
    Aug 2008
    No idea, I've never hooked up to it. I will check it out tomorrow though and post my findings.
    I'll log it under normal driving conditions and will post it up too, I should be about to data log it without licensing correct?
    Aug 2008
    On BBL I have captain (LS1 99+) module (LS1B_A) that should would?
    If you have an automative then yes, if manual then LS1B_M.
    Yes you can read the PCM/scan it/clear DTCs without licensing the PCM. Only when you flash do you have to license it.
  1. 5.3 Suburban w/22's
    By horsehaulin in forum Gen III V8 Specific
    Last Post: April 28th, 2010, 12:21 PM
  2. 2000 Oldsmobile Bravada w/ 4.3 liter engine
    By Kevin Doe in forum Vortec V6/V8 Specific
    Last Post: April 20th, 2008, 03:42 AM
  3. 0411PCM Suburban 4x4???
    By hquick in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 27th, 2007, 09:26 AM
  4. 07 suburban
    Last Post: August 5th, 2006, 04:03 AM
  5. Tuning '03 suburban with procharger, 1 bar
    By Chunx in forum General (Petrol, Gas, Ethanol)
    Last Post: January 24th, 2006, 12:37 PM
