I need some help with tuning a 2009 ZO6 Procharged car any help would be great.
Are you saying you need help purchasing software? Are you saying you need help setting up a wideband? Are you saying you need help reading a tune? Are you saying you need help knowing what tables in the PCM to modify?
What help are you asking for, exactly?
Mr. P.
Here is one piece of the puzzle: showthread.php?t=12693
BTW: welcome to the forum...
I have been Tuning for 3 years but have never done the new LS7 I need help with what Tabels to change just where do I start.I have software,and a good wideband,and an in house dyno its just that the LS7 is new to me.
Ok, so then you're familiar with doing AutoVE...
The E67/E38 ECM's don't have VE tables, they have VE polynomials...
The EFILive tunetool provides Virtual VE tables which render the VE polynomial factors in a virtual VE surface...
See this thread: showthread.php?t=8961
Post #38 contains the latest VVE tutorial pdf.
Adjusting the VVE's is not the same as doing AutoVE, but it uses some of the same concepts.
Have a read thru the VVE pdf's and see how you go...
By the time you read this, some other people will have added suggestions, comments, expertise.
Disable VVE, go MAF!
Install a 2.5 bar map sensor from a cobalt and scale it.
Deal with the dynamic section carefully and you are good to go
Install 60# inj.
Otherwise the engine will break.
Do you have dyno?
Car is too sensitive with timing adv...... what boost r u heading?
AFR shouldn't be more than 11.4 !!!!
LS7 block is too weak and break easy, just be careful.
Regards,
Odd Boy
just finished tuning my 07 Z06 ls7 with a 6psi procharger setup. If you need any info or help let me know the specifics.
Hi robertryan23,
Good job
Some questions:
- install a MAP sensor...?
- tune VVE...?
- tune MAF (or are you MAF-less)...?
- which injectors do you have...?
- how did you determine timing...?
- did you tune with the aid of a dyno...?
