Results 1 to 8 of 8
Thread: testing your coils
    Lifetime Member smslyguy's Avatar
    Oct 2008
    Default testing your coils
    are the ignition coil control circuit for 1-8 coils supported for the 2000 gmc's? And if so how do you select them? These are used for testing your coils, right?
    2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
    Now own a 2015 1LE camaro
    Apr 2008
    The combustion in the cylinder in general. Also, it is a tool that compares the efficiency of each one to others. It is a starting point to know if x cylinder needs a closer look.
    That includes coils, SP, injector....etc
    Regards,
    Odd Boy
    Are you talking about the injector controls under the DVT tab in the scantool...?
    Oct 2008
    NO, i was refering to the pids selection. I see i have an black x through them, but can't seem to find the correct pid selection to un-x them??
    Apr 2008
    I thought the samething DVT
    Regards,
    Odd Boy
    Oh, you mean STATE14...?
    Try selecting LS1B (99-08 LS1).
    Oct 2008
    i was referring to gmigncoil 1-8 pids. I will try selecting the ls1 though and see if this works. Is there much difference from selection the 98-00 vortec vrs the ls1 pcm? I mean you can select the ls1 pcm on a 00 gmc??
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Quote Originally Posted by smslyguy View Post
    you shouldn't have a 98-00 vortec PCM. that is the old blackbox that was used on the distributored early vortec L31 and L30 type motors. you have a gen 3 vortec which should be run with the LS1B 99-08 PCM IIRC.
  1. Spark Dwell w/ different coils
    By 99TransAmls16spd in forum Gen III V8 Specific
    Last Post: March 6th, 2011, 02:21 PM
  2. Mounting LS Coils on Gen 1 and Gen 2 SBC
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: June 18th, 2009, 10:37 PM
  3. Slightly OT: Replacing coils
    By Garry in forum Gen III V8 Specific
    Last Post: January 10th, 2008, 03:12 PM
