Is Delta_MAP/Delta_load the difference from the current frame to last/vice versa?
PHP Code:
#Units Low High Fmt Expression
*CLC-00-003
psi 0 16 .0 "({SAE.MAP.psi})-value({SAE.MAP.psi},frame()-1)"
kPa 0 105 .0 "({SAE.MAP.kPa})-value({SAE.MAP.kPa},frame()-1)"
*CLC-00-041
% -100 100 .1 "({SAE.TP})-value({SAE.TP},frame()-1)"
#Code PRN SLOT Units System Description
CALC.DELTA_MAP F003 CLC-00-003 "kPa,psi" Air "Delta MAP"
CALC.DELTA_LOAD F041 CLC-00-041 % Throttle "Delta Load"
What's this .cax file for?
