I may be purchasing a few streams from someone else with EFILive V2. Will I be able to put those streams on my cable or will it only work on his?
If it will only work on his, then obviously I will need his cable as well. If this is the case, do I have to change any of the software on my laptop or will it automatically recognize the change and change everything accordingly?
When I go to purchase another stream in the future, will I be able to get credit for the licenses I purchased using for my cable towards a stream for use with his cable?
Just trying to get some things cleared up before I buy.
Thanks - Josh
