Results 1 to 6 of 6
Thread: V2 in passthrough mode
    Feb 2006
    Default V2 in passthrough mode
    Is it possible to have the v2 hardware put into a passthrough mode so i can use it to talk to other devices on the obdi port?
    not looking to talk to the pcm, in fact it's my dash.
    Just wanted to see if it was possible before i looked at buying one of these.
    The dash programming is done via a vb program that i have decompiled.
    Oct 2004
    No, the FlashScan V2 can only be communicated with by the EFILive software tools. The device uses proprietary communications protocols, so it would not understand generic OBDII commands.
    Andrew
    EFILive Crew
    Feb 2006
    what about the v1?
    Oct 2004
    Same deal with FlashScan V1.
    Andrew
    EFILive Crew
    Feb 2006
    Quote Originally Posted by Tordne View Post
    Cheers, i ended up ordering the cable from my first post. Will see how that goes. the program im going to use just requires an aldl cable from the looks of it.
    Interesting thing i found after decompiling the program is the fact i might be able to rewrite the odometer values and few other things. But not that it's required for that use anyway.
    Feb 2006
    Im a retard, i baught the obdi2 cable because the car is an obdi2 plug, but because the program uses aldl i need to get an aldl cable.
    more waiting
  1. LBZ/LMM Passthrough issues
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 3rd, 2010, 11:55 PM
  2. Can't scan LLY in passthrough
    By Cougar281 in forum Diesel
    Last Post: October 17th, 2008, 02:54 PM
  3. PID Availablity problems in passthrough logging mode.
    By XLR8NSS in forum FlashScan V2 BB Logging
    Last Post: November 29th, 2007, 01:45 PM
  4. Passthrough data logging problems
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: November 28th, 2007, 04:23 PM
  5. Can Valet mode be used to turn SD mode off and on?
    By ForcedC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2005, 11:53 AM
