Results 1 to 10 of 11
Thread: Can't Validate ETC PIDs
    Oct 2005
    Default Can't Validate ETC PIDs
    Logging these used to work fine for me. Haven't done it in a while though.
    I cannot get the various ETCTP and ETCPP PIDs to validate. Have tried on 2 different vehicles that I have used it on in the past. I am using the latest versions of everything.
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
    Oct 2004
    I've just connected using 7.5.6 Build 101 to my test E38 controller and the GM.ETCPP1, GM.ETCPP2 AND GM.ETCTP are all valid. GM.ETCPP3 is not.
    Perhaps you just need to run the 'Info->Validate Modules' and 'Info->Validate PIDs' menu commands in the Scan Tool?
    Andrew
    EFILive Crew
    Oct 2005
    These are 2004 LS1 style PCMs. Build 101 as of today. Same issues yesterday with previous build. Validating PIDs does not make these become available.
    I can open up an old log by double clicking the file directly and the PIDs are all there, but as soon as I connect to the vehicle they become unavailable......see attached screen shots
    I am also seeing an error message when I try to retrieve DTCs.
ID:	6961   Click image for larger version.
ID:	6962   Click image for larger version.
Name:	DTC error.JPG
    Oct 2005
    Note that these are the sensor voltage PIDs that I need. They are found in the "sensor" grouping.
    Oct 2004
    OK. I have one of those PCMs here as well and confirm that I see the same issue with those PIDs being invalid.
    I don't get the error though when checking for DTCs?
    Paul is back from holiday late this week so it will have to hold for him I'm afraid.
    Andrew
    EFILive Crew
    Oct 2005
    OK. Thanks.
    It looks like the DTC read error is only occuring on one of the vehicles.
    I think I had read the DTCs, then I cleared them and the error message popped up at the point where you would expect it to return to the refreshed DTC list. Could be that the DTC clearing process did not complete properly??
    Oct 2004
    That error is a return code from a controller. So, possibly the clear process did not function - perhaps something else on the bus woke up as well and caused a reset.
    Andrew
    EFILive Crew
    Oct 2005
    Yes, the CEL is still illuminated.
    Oct 2005
    Well the CEL cleared itself after a few days of driving, but I still receive that same error message when trying to read DTCs from that PCM. Although I am assuming that there are no current DTCs stored at this time.
    Oct 2005
    Quote Originally Posted by Tordne View Post
    Any news on this? I have a customer's 102mm throttle body and hate to send it back to AU without confirmation that TPS signal ranges are satisfactory. It appears to operate well with the custom adapter harness I built for it, but I would like to confirm what the TAC module/PCM are seeing. For example, I don't want to be running a minimum TPSV of .38V on a circuit when .37 will trigger REP mode.
  1. cant validate rafig pids
    By rpmauto in forum General (Petrol, Gas, Ethanol)
    Last Post: April 2nd, 2010, 05:58 AM
  2. Can't get GM.AFR_B to validate in E67
    By JAY4SPEED in forum E37, E38 & E67 PFI ECM's
    Last Post: August 22nd, 2008, 05:55 AM
  3. Validate Modules?
    By Cougar281 in forum General
    Last Post: July 24th, 2007, 10:22 AM
  4. Can't get Boost PIDs to Validate??
    By 06bowtie_guy in forum Diesel
    Last Post: March 18th, 2007, 05:25 AM
  5. Can't validate RAFNG pid
    By 1bar in forum General (Petrol, Gas, Ethanol)
    Last Post: June 27th, 2006, 01:46 AM
