Results 1 to 7 of 7
Thread: Error: $0183 "Invaild Folder"
    Apr 2007
    Default Error: $0183 "Invaild Folder"
    I posted this over on Duramaxdiesels. But since this is more of a hardware issue I figured I would get a better response here.
    I went to use the V8 software to start adding PIDS to my V2, etc. I get the error message $0183 "Invalid Folder". I figured the SD card wasn't formatted, so I reformatted via V8 under the "Program" button. Still can't get it to work. I went to EFI Explorer and tried that way and also just going through the File System on the V2 it's self with no luck.
    I've used the SD card on BBL with great luck until now, it's a 2 GB.
    Thanks in advance.
    2011 Chevy 2500HD LML 4x4 LTZ-Black
    -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
    2012 VW Jetta TDI - Daily Driver.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Oct 2004
    The format button you clicked on actually formats the internal config filesystem (Flash memory section) and not the SD card. The SD card is formatted by pressing 'F4->F2->F3->YES' on the FlashScan V2 keypad.
    Andrew
    EFILive Crew
    Apr 2007
    I did that. Same error.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Oct 2004
    What is the firmware version on the FlashScan V2? The latest firmware provided with the V8 pre-release (20-Dec) software is 2.06.21.
    Andrew
    EFILive Crew
    Apr 2007
    Quote Originally Posted by Tordne View Post
    Firmware is 2.06.16. Bootblock is 2.06.02. Looks like a need a update.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Apr 2007
    That was my problem! Thanks!
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Oct 2004
    Phew, glad it was that simple :-)
    Andrew
    EFILive Crew
  1. Error: $0183: Invalid Folder.
    By kwhiteside in forum Black Box Logging
    Last Post: October 19th, 2009, 02:34 PM
  2. Error: $0183 Invalid Folder
    By Tre-Cool in forum Black Box Logging
    Last Post: August 1st, 2009, 08:47 AM
  3. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
