Results 1 to 3 of 3
Thread: need a tune file for a c5 corvette
    Oct 2005
    Default need a tune file for a c5 corvette
    Hello.
    I have just bought the new efilive program and I can get the car to start but thats about it. Kind of tough to find any details on how I setup a 3 bar map using main ve and/or bkup main ve.
    Is there anyone out there that could set me up with a tune file for a 1999 corvette. I will be glad to pay for this if someone can do immediately. You can also email me at louis@emailicon.net
    Thanks for your time and nice forum.
    I am running :
    F1C Procharger
    1400 cfm throttle body
    Kooks headers and exhaust.
    dart ls1 heads.
    stock block
    f1c procharger with twin intercoolers.
    3bar map
    1400 cfm throttle body.
    220/225 duration cam with 1.8 rockers.
    All roller lifters and rockers.
    75 lb high impedience inj.
    lingenfelter fuel pump.
    Sep 2003
    Here is the 3 bar tutorial and what you have to do to set it up in EFILive
    http://www.efilive.com/doc/Tutorials...20Tutorial.pdf
    You will also need the 3 bar map sensor and you will have to upgrade your 99 OS to a 2001+ Corvette OS. This in addition to the tutorial will get you where you need to be
    Larry - HumpinSS
    Oct 2005
    Default 3 bar tutorial
    Hello and thanks for the information.
    I have a 3 bar already setup. I did try everything already for the 2/3bar setup and got it running but it was not reading as a 3 bar. kpa was at 105.
    When I upgraded the os to new year there was one number off for my OS in the custom selections that did not match my os numbers. The last number was off by one and Im not sure how much that matters but I did get it to run just flooded with gas due to not reading 3bar.
    Would you know if this last digit would matter a lot in the custom tune files that are available on that site?
    We are in the process of checking the wideband 02 controller to make sure the stock ecu is seeing it.
  1. Need a 2006 Corvette 6speed auto file.
    By John02SS in forum E37, E38 & E67 PFI ECM's
    Last Post: March 16th, 2009, 02:16 AM
  2. Corvette AT 6sp File Needed
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 22nd, 2008, 05:17 AM
  3. I need a stock 04 zo6 corvette (Auto) file
    By dirtyratt in forum Gen III V8 Specific
    Last Post: March 15th, 2008, 09:32 AM
  4. Read a 1997 Corvette File Does this look right?
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: October 20th, 2005, 04:27 PM
  5. 2005 Corvette PCM file
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: August 24th, 2005, 02:58 PM
