Results 1 to 10 of 16
Thread: TBSS Tuning....
    Member 1BadAction's Avatar
    Mar 2009
    Default TBSS Tuning....
    What has everyone done, and how are they working? Erik, Jay, I'm looking at you guys Hot-Dog, where you at with the one you were messing with? You still around ft. misery? Big tex, you still messing around with yours?
    With the nice long run of cold weather upon me, I'm trying to get it running at its best, then when the hot weather rolls back around I'll be able to base the adjustments on what I have now. This summer I'll likely drop the big radiator in it along with e-fans, I'm not liking the electro-viscous one too much, truthfully.
    Jim
    2013 1SS/1LE Blue Ray Metallic Camaro - DD
    1991 2500 Suburban - Roller cam'd high compression 454ci BBC tow monster
    1979 16' Action Marine/"Johnny Cash" Merc Bridgeport Champ Motor - Metalflake Maniac
    1984 18' Contender Tunnel/2.4 Merc ModVP
    Apr 2007
    *Torque Managerment (TM) really kills performance and makes it feel soft. Reducing that can significantly help.
    * The PE of course needs some tweaking as well.
    * A really big problem with the TB SS is the ECT and IAT spark tables. They are really aggressive in some of the hotter temps and can reduce spark by as much as 8-10 degrees. You can really feel the difference.
    * The ETC tip in tables should be adjusted as well for crisper launches to get rid of the dead spot when flooring it from a stop.
    * Adjusting the tranmission shift speeds can firm up the soft shift points.
    Bone stock; I picked about 17whp (I have a AWD) and a lot morevtorgue in the lower-mid rpms with a relatively mild tune and it was still reducing spark at WOT. I've since tweaked it further and added a CAI. All in all, a tune make a night a day difference for the TB SS. Hope this helps.
    Mar 2009
    Are you talking about "torque reduction" on the up/downshifts in the T42 program, or are you talking about an 06 with whats called TM like the older vehicles?
    One of the things I have done on the E67 is smoothed out the flat spot in the "throttle tip-in tq reduction" table some. I also modified the burst knock and timing tables to get rid of that annoying off-idle stumble. Nothing wild, just making it like it should have been from the factory.
    Apr 2007
    Correct, it's called Torque Reduction in the T42 controller. I still call it TM, old habits die hard I guess. I have an '06. Good point about the Burst Knock; these have horrible false knock. My tables are reduced quite a bit as are the values in the Tip in Max Torque table.
    Mar 2009
    I have 2 degrees of KR from 4200 to 5800 no matter what the timing table says, stock, modified, etc. Its not knocking because I can't see it spiking in the log, so I desensitized the sensors just a hair. I actually think its the resonance of the exhaust doing it because its only when its in 2nd gear loaded, and I have a straight pipe where the main muffler used to be that resonates like a MF, lol.
    Unfortunately I havent really done anything to my SS except throw that BBA tune thats been floating around on the tbssowners site. Its alright, but its not anywhere close to perfect thats for sure. I can tell the SS is a lot more picky engine to engine than the 4.2L I6 is. Still driving my 02 around for now, did some wideband logging and minor tuning on it again but EFILive still doesnt have 3 critical PIDs that any tuner needs to get the VE table dialed in perfectly yet.
    Ill be driving the SS full time starting in a week and a half when it gets brought to me here in Spokane, then Ill get my wideband bung welded in and get it installed. Finally Ill be able to get some nice long logs around town and on the highway with the PIDs setup properly for AutoVE and then start messing with spark.
    Apr 2007
    Indeed the TB SS is finicky to tune; much harder than a LS1 car. It took me countless logs and tunes to get it right, but well worth it in the end. I do want to get a WB bung welded in so I can monitor the AFR.
    Quote Originally Posted by DrkPhx View Post
    Yea, I bought an LC1 with a blue AFR guage that I had in my 02 for a few months and took out on the 27th of Dec so I could pass emissions and get new plates/tabs for my 02 before my trip to Canada. Going to have an exhaust shop weld in the bung here in a few weeks when I get a chance after the 20th and then wire everything up.
    Love the Serial output, makes the connections a breeze.
    Great to hear the SS is harder than an LS1 to tune...just what I wanted to hear. But I imagine the P10 is harder than both so I should be alright lol.
    Mar 2009
    Believe it or not, I've had the bung welded in for almost a year now, and the LC1 unit riding under the hood without power or a sensor on it. I will probably hook the WB up tomorrow and go from there. I also need to do some data logging with a boat hooked up, but I don't think that will be much of an issue.
    Like I eluded to in the previous post, in my own mind, I can't justify tuning in the heat of the summer. I would rather do it now and let the IAT and other heat based tables do their job in the summer (obviously tweak them where needed). Then I know for sure when it gets cold again, as rare as that is here, that I'm not leaving anything on the table.
    Over the last year or so I've been making mental notes of some of the bullshit the transmission does, and I finally wrote the tune to the transmission friday evening. As far as I'm concerned, I NAILED it. No more goofy slip-n-shifts, no more putting my foot to the floor at 35 and not having it shift into first like it should, no more 1/2 second long shifts, it just goes.
    I had a 200 mile long ride home today, 55* IATs, 0-60 I couldn't clock, but 80-100 took 2-1/2 seconds and 80-120 took 6. not bad for a 4800lb truck with a full gas tank, another 300lbs of vacation stuff, tools, and fishing gear in it. A dead OEM battery in the back too That is a very mild tune, still have 20 to 25% shift torque reduction (down from 30-35, stock) and the max timing is maybe 2 degrees more than stock where it counts. The extra little bit of timing really wakes this truck up in the meat of 2nd and 3rd gears.
    Mar 2009
    You got that right. The trans is relatively simple (to me anyways), but the weight and aerodynamics of the truck has a big effect on how far you can go with certain areas of the engine tune. I have a feeling after I get the WBo2 in it, and get the fuel where it needs to be, that I will need to make some changes to my spark tables, that's why I'm being ultra conservative with the changes right now. Hell, I noticed in my logs that the LTFTs are around -8 and -10%
  1. TBSS (E67) some odd issues.
    By E.A. in forum E37, E38 & E67 PFI ECM's
    Last Post: August 4th, 2011, 02:20 PM
  2. 08 tbss ???
    By blackdeath in forum E37, E38 & E67 PFI ECM's
    Last Post: February 24th, 2009, 02:42 PM
  3. TBSS: Logs and Tuning
    By 4DRSS in forum Gen IV V8 Specific
    Last Post: July 2nd, 2007, 05:01 PM
  4. 07 Tbss
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: June 19th, 2007, 03:17 AM
  5. Stabilitrak on TBSS
    By mwalls54 in forum Gen IV V8 Specific
    Last Post: May 6th, 2007, 11:43 AM
