Results 1 to 10 of 10
Thread: Interface not detected problem
    Dec 2009
    Default Interface not detected problem
    I can log data just fine with just the hand held. I can download scan files from my hand held to the laptop and update PID selections on the hand held. I cannot get the pass through to work. When I hit the connect button in the scan software on the laptop I get an interface not connected. When I try to look at the scan data on the hand held it says it is in pass through mode. I am just a getting my feet wet in this.
    The truck is an 08 silverado and was successfully tuned in person about 3 months ago with efilive.
    Any ideas? Do I need to pull a fuse or am I not hitting the right buttons in the software?
    Aug 2008
    When you click connect,(a picture of the Computer you want to connect to should pop up) make sure you choose the right ECM. If it's a gas truck it should be an E38 and for the transmission it should be a T42...
    Also, make sure you are finished logging data before you connect to your laptop. I usually just disconnect and then re-connect my V2, from OBD2 port, just before I want to use it in pass thru mode...Hope this helps
    FLASHSCAN V2 & AUTOCAL
    Dec 2009
    I do get the popup and I'm choosing the E38 and t42. So far so good.
    I've tried 4-5 different start up scenarios. Boot laptop, connect hand held, plug in to obd2 port. The reverse order of that. plug hand held into obd2 port verify it is talking and plug hand held into laptop. I can unplug the hand held from the laptop and back in and verify it is going into pass through mode. Just cannot figure out why it is not connecting.
    thanks for your help
    Aug 2008
    Might be USB/laptop related....
    Is the truck On while trying this? Or atleast KEY in ON position vehicle off...
    Dec 2009
    Tried with the key in the on position and while the engine is running. If it wasn't so darn cold outside I would go troubleshoot some.
    Dec 2009
    resolved the problem thanks. feel like a DA
    No worries, we all fall into some hole or other at various times...
    Aug 2008
    What was the problem?
    Dec 2009
    if you must know I didn't realize that you had to push the yellow button at the bottom of the screen to start recording. I thought that all you had to do it select the green button in the upper left corner. not sure what the interface not detected message was but all seems functional now.
    Yellow button monitors, Red button records.
  1. pcm noy detected on scan only wtf?
    By z28ls1818 in forum FlashScan V1
    Last Post: December 15th, 2009, 04:32 AM
  2. error interface not detected
    By drdarthinvader in forum FlashScan V2
    Last Post: December 7th, 2008, 06:11 PM
  3. What could cause timing to be pulled with no KR detected?
    By ArKay99 in forum Gen III V8 Specific
    Last Post: September 15th, 2008, 10:09 AM
  4. Sudden "No Interface Cable Found" problem
    By mtnman in forum General
    Last Post: November 22nd, 2005, 05:26 PM
