Results 1 to 4 of 4
Thread: LBZ Turbo brake
    Jan 2010
    Default LBZ Turbo brake
    Can some one tell me the correct values for the turbo brake that will work only in tow haul mode that won't hiss all the time and have vane buzz when shutting off the truck. Truck is completely stock. I just want to add the brake. Thanks in advance.
    Jan 2008
    In the desired vanes position tables. (EGR ON and OFF) {since you are stock} in the top 2 rows set the vane position to 80-100 percent depending on what you like. and in the MAX VANE position table set those values in the top 2 rows to MORE that what you have commanded. and for the buzz B1501 set to disable. But you really only get the buzz if you have altered the idling section of the vanes.
    Lifetime Member LBZoom's Avatar
    Jun 2008
    There isn't a way to set it so that it only comes on with tow/haul either...sorry man
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
    Mar 2008
    You just have to learn to drive the truck with it on. Keeping your foot on the throttle some while coasting might help.
    06 GMC 2500 CCSB SLT LBZ 4X4
    These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  1. Anybody run a tranny brake?
    By acomp917 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 28th, 2010, 07:10 PM
  2. Brake downshift
    By L31Sleeper in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 18th, 2010, 04:31 PM
  3. Turbo brake
    By maxxflip in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 9th, 2009, 09:39 AM
  4. Closing turbo vanes for turbo braking?
    By Haulinbass02 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 14th, 2009, 11:12 AM
  5. turbo brake switch??????
    By justin123 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 13th, 2009, 01:14 PM
