Results 1 to 10 of 12
Thread: 6 Speed Allison TCM's
    Default 6 Speed Allison TCM's
    Are the LBZ & LMM A40 TCM's the same except for the programming, meaning if I program a calibration for a 2007 LMM into the TCM I have that's out of an 06 LBZ, would it work or could I expect problems?
    I would think you would have to full flash the os into it, we cant full flash the 6 speed yet. I have never tried it but I bet it wont even do a calibration flash since the os is different who knows?
    04 LB7
    2010 LMM
    2015 LML
    Quote Originally Posted by rcr1978 View Post
    Can with a Tech2
    Sorry, should've mentioned that I was referring to changing the cal with that, not EFILive.
    Jan 2008
    Didn't know there had been different cal's released for the light duty trucks. I know there are a few for the MD's.
    I would say that if you have found a setup you like in another TCM i would FULL flash with the Tech II since we don't have those TCM's fully developed yet. And grabbing just the cal might not net you the results you are looking for.
    Quote Originally Posted by bballer182 View Post
    What I am asking is if I flash an LMM A40 cal into my LBZ A40, will it work in the LMM or is there a difference in the hardware? Where the Tech2 is concerned, the "Cal" is the entire OS (at least all the flashes I've played with in the A40 where 2MB). The LMM cals are different form the LBZ's in that the LBZ's still use Class2 for some things, whereas the LMM's don't. The 8.1's have PWM torque management enabled whereas the Duramaxes use J1939 for Torque management... Then there are the below -40 cals and "normal" cals....
    I think you should be fine to exchange LBZ & LMM OS's without harming the TCM, the hardware only changed for 2009 (as you know).
    What did you conclude Dave?
    Custom Tuning Services
    Yes, you can flash a LMM cal into a LBZ A40 and vise versa; All the A40 hardware is the same. I was also able to flash several MD cals into the same TCM wothout issue.
    Dec 2006
    What changed in the hardware for 2009?
    8.7 @ 84 (1/8 mile) bolt-ons
    I am confused (a perpetual state). LMM and LBZ have the same OS?? Didn'tthe LBZ A40 have an LBZ OS? With no full flash capability, hence my confusion.
  1. Allison 6-Speed PIDs
    By 8100 Power in forum Diesel
    Last Post: September 29th, 2008, 01:58 PM
  2. BBL PID's for Allison 5 speed
    By turbo_bu in forum FlashScan V2 BB Logging
    Last Post: August 19th, 2008, 04:32 AM
  3. Allison 6 speed
    By lucky1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 10th, 2007, 11:50 AM
  4. 6 speed Allison
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 21st, 2007, 11:03 AM
