Results 1 to 10 of 20
Thread: Setting the record straight on Gen IV ADM/DoD and VVT
    May 2009
    Question Setting the record straight on Gen IV ADM/DoD and VVT
    Ok...everyone loves using Wikipedia's highly informative LS-based but it and LS1Tech are not helping.
    Am I correct in understanding that until the advent of the '09 Cadillac Escalade Hybrid LFA and '10 Escalade L94 no previous LS motor has had AFM/DoD AND VVT?
    Also, for those with a bit more mechanical knowledge, am I to also understand that adding VVT to any Gen IV simply requires the hardware of the timing cover, actuator, VVT cam, and notched pistons?
    Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
    Aug 2007
    I have a 2008 Impala SS and it has DOD and I think it goes back to 2006 on the LS4 engine. I'm not too sure on the VVT
    Aug 2008
    07 on trucks, 5.3ltr, 6.0ltr, 6.2ltr
    FLASHSCAN V2 & AUTOCAL
    Jul 2007
    Quote Originally Posted by TBMSport View Post
    And ECM with suitable tune.........
    From memory, the phasing is done via oil pressure fed from the cam bolt, hence why they went to a single bolt. The font half of the stock cam is hollow and there is an oil feed hole in number 2 bearing journal. The blot would then have a feed hole to provide oil pressure to the phaser.
    In the Aus Gen IV engines I've seen, the bolt in the cam is a solid unit, so this would also need changing. I'll see if I have any pics available.,
    Simon
    Dec 2008
    In the full size trucks... 07,08,09 5.3's had DOD only. 07,08 6.0 (L76) had DOD and VVT.
    A few early 07 6.2's (L92) had DOD and VVT, but they were pretty rare as far as I have seen. 08 6.2's only had VVT. L76 6.0's in the cars (G8's) had DOD only, no VVT. 6.0 GTO's had neither DOD or VVT.
    I'm not in sales and I don't order the trucks so I could be off on a couple of these, but afaik that's how they came.
    Member JAY4SPEED's Avatar
    Mar 2007
    I know the 2008 LY6 ironblock 6.0L has VVT but not sure on AFM.
    Dec 2008
    LY6- VVT no AFM sometimes EIEIO
    Aug 2008
    My 08 Silverado L76 has AFM, DOD, VVT....i think...
    Jul 2007
    Here you go. Some pics of the front of the "VVT Capable" cam.....
    First up, bearing journal #2. You can see how the oil is fed to the center of the cam.
    Next, the front of the cam. Note the plug half way down the cam, to stop the oil running out the back. Also the 2 oil feed galleries and wider bolt hole to allow oil to flow in to the VVT adjuster.
    Simon.
    Aug 2008
    Swingtan, did you take your engine apart just to get us some pics.... J/K
  1. Replies: 41
    Last Post: April 27th, 2009, 02:10 AM
  2. BBL data display/record decimal places
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: March 27th, 2008, 03:46 PM
  3. How do I make flashscan record RR?
    By 99ss in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 18th, 2007, 02:55 PM
  4. Scan Tool won't monitor or record
    By ForcedTQ in forum Petrol / Gas
    Last Post: August 25th, 2007, 12:15 PM
  5. Dual spark maps, let me get this straight????
    By nitrorocket in forum Custom Operating Systems
    Last Post: August 9th, 2006, 11:16 AM
