the scan tool has a preloaded map for the throttle cracker. but when i look under map properties it says i have to select the throttle follower pid gm.iac_tf_dma. now im no expert but shouldnt i be logging gm.iac_tc_dma which is the throttle cracker. this is on the new update version that it has it like this. on the older version it says to log tc. im confused. also when i open the preloaded map for the throttle follower it says to log gm.iac_tf_dma which is the correct one right.
basically what im saying is why is the tc preloaded map say that i need to select tf pid and not the tc pid.
