Results 1 to 5 of 5
Thread: selecting PID priority
    Jun 2009
    Default selecting PID priority
    hi Eric here , i am not able to change PID priority , been over the manual but still can not figure it out , can anyone tell me how simple it is , thanks alot
    Oct 2004
    I'm not aware of a way to do it in the software (never really looked actually). But, if you open your PID file with a text editor you can change it:
    Default - Priority 1
    GM.AFR=1,589
    Changed - Priority 2
    GM.AFR=2,589
    Andrew
    EFILive Crew
    On the PIDs tab you can rightclick and you can see the setable priorities... but they are all greyed out... this might be a bug.
    On the [Data F9] tab page, use Ctrl+1, Ctrl+2 and Ctrl+3 to set the priority.
    The right click menu that you can see on the [PIDs F8] tab page should also exist on the F9 tab page (it's a bug that needs to be fixed). When the bug is fixed and the menu is available again on the F9 tab page the three priority setting menu items will be enabled for the F9 tab page.
    Jun 2009
    thanks guys it works with the Data tab and using Ctrl 1,2 and 3, i am sure you guys will fix the bug , i would like to tell you all at efilive that your service here on this forum is great and its also great the way the users help each other out wow , thank you Eric
  1. Need Help Selecting PIDs in BBL
    By dinorex44 in forum Black Box Logging
    Last Post: May 10th, 2009, 04:18 AM
  2. selecting pids on v2
    By Aint Skeered in forum FlashScan V2 BB Logging
    Last Post: December 9th, 2008, 04:44 AM
  3. selecting pids files ?
    By drdarthinvader in forum FlashScan V2
    Last Post: October 12th, 2008, 08:30 AM
  4. Selecting PIDs
    By mnotx in forum FlashScan V2 BB Logging
    Last Post: September 6th, 2008, 01:12 AM
