Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: BBL SD Card Error Work Around
  1. #11
    Abdulla,
    which V8 software build version are you using...?
    which V2 firmware version...?
    See here: July 5th prerelease.
  2. #12
    Junior Member Abdulla's Avatar
    Jul 2010
    - EFILIVE Explorer 8.1.2 build 105
    - Firmware version 2.06.35
    - Bootblock version 2.06.03
    After formatting the SD from PC it worked fine and could get files transfered to V2 SD and could log some data from the vehicle.
    However- after my 1st succesful logging- I gave it a second try to get the SD formatted by V2. and this time it worked fine unlike the first time when I installed the SD card, and I tried to log.. no problems.
    It seems there is something wrong with V2 getting SD working properly first time. (@least in my case)
  3. #13
    Nov 2006
    Should the SD card file system be FAT or FAT32?
    LC-1 WBO2
  4. #14
    Jul 2010
    I used FAT32
  5. #15
    Jul 2007
    FAT32 should be fine.
    Just rememeber to "recheck" the card status when the card is first inserted into the V2 as described in the first post. It seems to work fine after that. Also remember that if you format in a PC, you need to create the following directories on the SD card....
    \EFILive
    \EFILive\Scan
    \EFILive\Tune
    Without these you will have problems.
    One more point, the copying of the config files should have nothing to do with the SD card. All the config files go an an internal memory chip that is separate from the normal user mass storage.
  6. #16
    Nov 2006
    Default [f4]-[f2]-[f1]
    This worked.
    I can finally get a log on the SD card.
    LC-1 WBO2
  7. #17
    Oct 2004
    And also create \EFILive\Tune\Read
    Andrew
    EFILive Crew
  8. #18
    Nov 2006
    The V2 does this when formatting the SD card.
    LC-1 WBO2
  9. #19
    Oct 2004
    Yeah I know
    Was just an "in addition" post to #15.
    Andrew
    EFILive Crew
  10. #20
    Senior Member MyM8V8's Avatar
    Aug 2008
    I'm not very IT literate, but is this anything to do with the different speeds that cards are available in? Do we need to buy the fastest ones like they have for digital cameras.
    I remember some time ago having issues with card speeds on a compressor sequencing controller. We had to get quicker ones ro we had problems.
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
  1. scanner buttons work work?
    By pullincrazy88 in forum FlashScan V2
    Last Post: May 16th, 2009, 01:12 PM
  2. SD card
    By FeetDry in forum FlashScan V2
    Last Post: September 23rd, 2008, 05:12 AM
  3. Dead SD Card
    By Cougar281 in forum FlashScan V2 BB Logging
    Last Post: January 6th, 2008, 03:35 AM
