Results 1 to 10 of 13
Thread: Min airflow actual gear different to logg
    Senior Member alian's Avatar
    Jun 2008
    Default Min airflow actual gear different to logg
    Sorry for the long title but wasnt sure what to call it. Has anyone else noticed that when you highlight a section in your chart then go into the tune the next gear up is highlighted. So if I pick a section in the chart say that is in third gear of the log, then open up the tune the cell highlighted is in min airflow isin the 4th section. I thought my pid might be wrong but in top gear it highlights 5th gear in the tune.I have a A4. Not sure why.Cheers Ian
    Hi Alian,
    Post log file, tune file, screenshots.
    Joe
    Jun 2008
    I am not to sure how to attach the screen shots.
    Ian
    Jun 2008
    See if this works. cheers Ian
    Quote Originally Posted by alian View Post
    Ian
    Ian, there are two ways, hosted or attached, see this: showthread.php?t=3064
    Do you have the log file and a tune file so I can play with it...
    Jun 2008
    Have sent via Email.
    Cheers Ian
    Ok, I got them.
    Jun 2008
    Ok, I got them.
    The way I have the min air at the moment it dosnt matter, I was just unsure
    if anyone had noticed this.
    Cheers Ian
    Default B1829 wrong GEAR value (ST->TT linking)
    OK, I see it happening for all gears (1,2,3,4)...
    The GEAR axis shows the wrong value for B1829...
    Are there any other tables that have GEAR as an axis...?
ID:	7055   Click image for larger version.
  1. I did a nice logg and trying to understand it.
    By lilicedout24 in forum Gen III V8 Specific
    Last Post: February 23rd, 2010, 02:45 PM
  2. Desired airflow won't equal measured airflow
    By Ryan in forum Gen III V8 Specific
    Last Post: June 4th, 2008, 09:17 AM
  3. Interesting BB logg data ...
    By Garry in forum Black Box Logging
    Last Post: June 2nd, 2007, 07:44 AM
  4. Question about calculated airflow vs. measured airflow
    By JR_VETTE in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2006, 05:37 PM
  5. Throttle Cracker Airflow in Gear
    By DaleMX in forum General (Petrol, Gas, Ethanol)
    Last Post: December 29th, 2005, 03:06 AM
