Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Slowing up the stftrims coming in so early.
  1. #11
    Lifetime Member hymey's Avatar
    Jan 2008
    Quote Originally Posted by alian View Post
    Yes that was a cold. Have done a couple of things, 1 was to align 1501 and 1503, 1502 and 1504.Not sure how long they have been different. Will have to go back to see when and if they were changed. I seem to have come up mwith a happy medium that is working for me. Thanks Simon and Joel. Again you have proved that the more you play the more you learn.
    Cheers Ian
    Ok its strange that its leaning out there. I can normally here mine go into CL when its warming up by 60 degrees STFT kick in and the engine note changes. But its not lean, only when hot I had this trouble.
  2. #12
    Senior Member alian's Avatar
    Jun 2008
    Quote Originally Posted by hymey View Post
    Joel This is a problem I have had since I started tuning the car. Once I had tuned it maffless and went to turn on the sftrims it was doing it. It is the reason that I have always stayed with an OL tune.Now it seems to be working, But I will do some more testing at different heat temps.
    Cheers Ian
  3. #13
    Dec 2007
    I have seen STFT's start up 3 sec after a cold (warm ?) start from memory. Stock tune. So maybe this is the same thing.
  4. #14
    Jan 2008
    I see the advantages of stfts as simon has pointed out. On open road trips my economy improves in CL around town its better in OL. But overall CL is better with the e38. It has its niggling issues from time to time. 3 seconds I have seen this too. I too go through times of using OL and improving low speed tune. Using the MAF solves a lot of things and my drivability is better although I am down 2-3 kpa with MAF on.
  1. 2-->1 Downshift while slowing down noise
    By 1fastgto in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 26th, 2010, 02:42 AM
  2. Early E38 vs. New E38.....
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: April 3rd, 2010, 07:50 PM
  3. A/C surges when slowing down
    By whackem04 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 1st, 2009, 02:02 PM
  4. Slowing down IAC ?
    By slowhawk in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2007, 04:04 AM
  5. slowing down surging
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: January 30th, 2006, 10:38 PM
