I saw nothing in the parameters to change trans functions,I also tried to pull the trans data from the ecu and that didnt work either.How do i make changes to the trans in the a6 car.
Have to read the TCM out seperately. Once you have pulled the ECM tune (E38 IIRC) then you need to go back into the read window and select Transmission 6spd T43 TCM and read it out.
i tried that gave me a error message.hmm i will try it again.thanks just makn sure i was doing it correct lol.thanks for the input.
