Results 1 to 10 of 14
Thread: Missing Table B3647 after full reflash
    Lifetime Member MN C5's Avatar
    Mar 2005
    Default Missing Table B3647 after full reflash
    O.S. 12587603 got the Boost VE table and timing table for boost but was left with AFR commanded by coolant temp.
    Could it be that I might have missed an update to a cal file or custom tun file?
    Sep 2003
    The latest cal files are 1.71 do you have those
    Larry - HumpinSS
    Oct 2005
    Do a search for "B3647" in the tuning navigator. In the description box mine says "not available in this OS". :cry: Needless to say, I was a little disappointed at this point in my custom OS install yesterday. Still have tuning to do.
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
    Mar 2005
    Mine says 7.70, but is it something thats fixed in .71 or was there never a problems and was my issue A-typical?
    I don't have the vehicle available to check by reprogramming 7.71....
    Dennis
    Oct 2005
    Just noticed that we have the same OS. Sure would be nice to have that table(see my post).
    Mar 2005
    TTT
    Lifetime Member Scoota's Avatar
    Mar 2005
    For the 12587603, you should be using 04073003 CO's.
    You won't find B3437 in a stock OS.
    Dennis, one would assume you are not using the CO system when you mention the 12587603 OS.
    Cheers Scotty.
    It's a lot easier to ask for forgiveness than it is to ask for permission.
    Mar 2005
    Quote Originally Posted by Scoota
    Cheers Scotty.
    Ok, to clarify the table is missing from the Custom Operating System 04073003 as it replaces stock OS 12587603. Sorry for the confusion, but the problem is as I described it in Custom OS 04073003. The table is not replaced, and I don't have the vehicle here to test with the latest updates.
    Oct 2005
    I'm using version 7.71 of this same custom OS. B3647 description says "not available in this OS".
    Same goes for B3601.
    e.g.
    Under A0008:
    "When using {B3647} "(not available in this operating system)" to define the commanded fuel, this table is used as multiplier based on engine coolant temperature.
    A number of 1.00 will add no more fuel based on the engine coolant temp, any number higher than that will add fuel."
    Under B4206:
    "When disabled, the PCM will always use
    - {B3605} Commanded Fuel When in Open Loop or
    - {B3647} (not available in this operating system) as the fuel mixture table without any O2 feedback as long as table
    - {B4205} Closed Loop Temp Enable is also set to it's maximum value."
    Under B3605:
    "When the engine is in cold open loop mode, this is the commanded fuel.
    See also:
    - {B3601} (not available in this operating system)
    - {B4205} Closed Loop Temp Enable"
    Yeah, they are missing from those cal files.. :?
    Looking into it.
    EDIT:
    Download the updated .cal files for those 2004 O.S's here -
    http://www.efilive.com/upload/public/MISC/040xxx03.zip
    We will update the main download page soon.
    Sorry for the drama's.
  1. cant do full reflash???
    By Madspeed in forum Duramax LB7
    Last Post: April 28th, 2010, 12:46 PM
  2. full reflash
    By SGFastMax in forum Duramax LB7
    Last Post: June 13th, 2009, 10:56 AM
  3. T43 Full Reflash
    By ntrimm in forum Gen IV V8 Specific
    Last Post: April 19th, 2009, 11:59 PM
  4. Cant do a full reflash on LMM?
    By dmaxallitech in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 21st, 2008, 03:00 PM
  5. Full reflash ?
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 2nd, 2006, 01:05 PM
