If actual mm3 > B2231 ECM controls boost
If actual mm3 < B2232 ECM does not control boost
Now by saying does not control boost is not 100% correct, but it bypasses the PID controller for boost so it should just aim for the base boost values.
If you look at the numbers in those tables you can see at idle they bypass the PID, above that it's pretty much enabled the whole time.
