Results 1 to 10 of 14
Thread: LMM-Turbo Vane Target Position
    Jan 2006
    Default LMM-Turbo Vane Target Position
    os 594, There are 6 or 8 of these tables. I noticed that some of these have a different vertical scale than others. Is this intentional? All go from 0-120 fuel, but they are graduated differently.
    Custom Tuning Services
    This is the scaling in the tune, not sure why GM chose those breakpoints, they changed again in the LMM from memory.
    Junior Member husker_diesel's Avatar
    Mar 2009
    which table are you talking about specifically?
    Jan 2006
    B2210-B2215
    B2215 has a lone wolf vertical scale, different from the rest.
    ok, now I know the one you mean. I don't have an answer as to why GM (Bosch) chose to make this table different to all the others doing a similar function. But the table size is defined in the calibrations as 16x16, not the normal 23x23.
    Jan 2006
    While on this topic, I am having a real struggle with boost. From what I can assess, I am getting a vane position command, not a boost command. I can depress the pedal, and vane will rise, and stay right at, say 50%. No modulation, flat line. I would expect the vane pos to be all over the place working the boost set point, and that is not happening. The boost will rise, slowly, in response.
    The end result is high boost, and eq ratio sometimes below 0.6 on accelerations. That's clear cut overboost for tuning purposes.
    Any ideas? B2231 and B2232 do not appear to be in play here.
    Jan 2006
    Shows what i am talking about. Constant vane ops, as opposed to constant boost.
    Jan 2008
    I see you have found a suitable "number" for the EQ ratio for the lbz/lmm. did you use the first half of my equation and dial in the "number" to obtain the correct eq ratio?
    Jan 2006
    Honestly, IIRC, I am using the same equation from earlier gen. The original equation.
    It is really entertaining to watch it when the EGR kicks open. Watching MAF drop by 70% is a hoot.
    Mar 2007
    Ya and you can feel the power loss, a real hoot.
  1. Turbo Vane Target Position Question
    By dieselz28 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 21st, 2010, 12:38 AM
  2. Too much boost and Turbo Vane "TARGET" Position-LMM
    Last Post: November 5th, 2009, 09:27 AM
  3. Min. turbo vane position?
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 9th, 2007, 10:56 PM
  4. VVT Vane position
    By killerbee in forum Duramax LLY
    Last Post: September 18th, 2006, 03:58 AM
